#16
Re: 4L30E Bang Shifting into 3rd
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k |
#17
i'm interested in figuring out why that worked. afaik, there is no vacuum connection that feeds to the 4L30E automatic transmission. it is controlled totally by the trans computer and the gear selector. i'm thinking that one of the many inputs to the trans computer may be influenced enough by the vacuum leak to adversly affect the transmission shifting. the inputs include: rpms, vehicle speed, engine coolant temperature, ac info, throttle position sensor, kickdown switch, power/winter switches, mode switch, brake switch. the trans computer is programmed to transmit specific commands for actions to the trans under a full array of different circumstances. my guess is that the trans computer received conflicting data -- e.g. high rpms and low engine speed, and closed or closing throttle -- and thus sent conflicting info to the trans, which promptly took the conflicting actions, which results in the slamming shifts. (similar to the way when a bad gear mode switch sends incorrect gear position to the trans computer; the trans receives conflicting info from the gear selector and from the trans computer -- which can cause among other things very harsh up and downshifting.) i think, iskiuskiweski, your feedback is very valuable, and the first i've heard of that connection. it should help many in the future. i like trying to reconcile the symptoms and diagnosis's and actual results so that a future anomoly is easier to "see". thanks again.... anybody have their own take on what's going on here with the IMG leak and the trans harsh shifting? anybody else have this same problem/solution? thanks //bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
#18
i had the same problem from 1st to 2nd. on mine it just meant that my tranny fluid because when my brother had the car before me, he lost the dipstick to the tranny so he never knew how much fluid he had-therefore, the transmission went out, he gave it to me, n i had to put in a new tranny in n ive got a dipstick in the new one n mines doing great
-david |
