Old 09-09-2006, 08:33 PM
hypnoman55's Avatar
hypnoman55 hypnoman55 is offline
Re: 1990 camaro rs probelems
battery and starter ok cheched it thanks !!!!!!!!!!
Old 09-18-2006, 08:40 PM
hypnoman55's Avatar
Originally Posted by corning_d3
First thing i'd do would be to test for battery voltage at the starter, then test for battery voltage on the wire coming from the ign. switch while the key was turned to start..
tested battery ok change switch still no crank!!!!!!!help anyone please 111
Old 09-18-2006, 08:42 PM
hypnoman55's Avatar
Originally Posted by TEXAS-HOTROD
Pull the coil wire from the distributor and install a good spark plug into the boot. Lay the plug on something metal, crank it over and check for spark. If it has spark, install the coil wire, remove a spark plug wire and do the same. If it doesn't have fire at the plug wire, it's the cap/rotor. If it does, install the plug wire.
Remove a main vacuum line (PCV valve works good) and shoot some carb cleaner down the tube. Crank it over and see if it will try to start, or if it will start and die. If it does start/tries, then most likely it's the fuel pump. If the fuel pump went out, it's caused by a plugged fuel filter.
You don't want to guess at what's wrong and throw parts at it. That'll just cost you extra.
Check for fire and post back.
WON'T CRANK TO CHECK!!!!!!!
Old 09-19-2006, 12:01 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Is the switch sending battery voltage to the starter?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 09-19-2006, 07:17 AM
hypnoman55's Avatar
just changed the key switch and the switch on the coluum ,but nothing when u turn the key on yet!!!!!!!, but when i cross the wires at the starter the cranks the engine .
Old 09-19-2006, 07:23 PM
hypnoman55's Avatar
still won't crank!!!!!!!!!help!!!!!!!!!
Old 09-20-2006, 08:52 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Has to be VATS related then
Old 09-20-2006, 07:15 PM
hypnoman55's Avatar
u think so i put a new key and switch!!!!!!!
Old 09-20-2006, 08:50 PM
You never said whether the small terminal on the starter had 12 volts when you had the key in crank position...
Old 09-21-2006, 09:24 PM
hypnoman55's Avatar
going to check that this weekend thanks!!!!!!!!
Old 09-23-2006, 07:01 AM
Blue Bowtie's Avatar
Registered Offender
Originally Posted by Blue Bowtie
Fusible link, anyone? VATS would not have shut it off, but would prevent restart depending upon the failure mode.
I'm guessing this is not your primary mode of transportation. That was two weeks ago. Replacing the ignition lock cylinder does not address the VATS, and may have aggrevated the situation if the resistance of the new cylinder and key is incorrect.
Old 09-27-2006, 07:04 PM
hypnoman55's Avatar
Just got it back in garage checking if the starter has 12 volts thanks !!!!!
Old 09-27-2006, 07:05 PM
hypnoman55's Avatar
the new switch is the same resistance thanks !!!!!!!!
Old 09-28-2006, 07:03 AM
Registered Offender
Just a few more questions:
  1. Do any of the instrument panel warning lamps illuminate?
  2. Do any of the power accessories operate (radio, wipers, windows)?
  3. What happens to the SECURITY lamp when the ignition is tunred to the RUN position?
  4. When you hold the key in the START position, does the temperature gauge climb? Do the dash warning lamps illuminate?
  5. Have you tried starting the engine with the transmission in neutral?
Old 10-02-2006, 10:48 AM
hypnoman55's Avatar
yes !!!!!!!!
