Old 08-25-2006, 01:46 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: Stupid Car problem!! Please help.
yep and they should be blinks not beeps in obd-0
Old 08-25-2006, 04:16 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
it's like,
short blink= -
long blink= _
ok now
short blink value of 1
long blink value of 10
now add
_ _ - -
that would be a 22 code
get it?
it's really easy, you'll get it.
-tony-
2000 honda s2000
Old 08-25-2006, 07:44 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Okay, smartass, I edited it.
BTW, hondacivic99sivtec, if it's a stock engine it doesn't go one long blink for 10... Jeez... not everybody has a swapped engine and ecu in their car.
If you have a stock engine in your 88-91 civic/crx and you have a code 17 (speedometer cable) for example it will blink 17 times like *****************...
If you have a code 1 (Oxygen content) for example, it will blink 1 time and pause and repeat like *___*___*
Get it?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 08-25-2006, 12:16 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yes, ive realised that b16 ecu's are different, they will blink one long time for 10,
But the stock ones will just blink 10 times.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-27-2006, 09:16 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
well i have a Z6 engine with the stock pm6 ecu. vtec is not hooked up. tonight it was annoying. my headlights kept going dim then bright, and everyone thought i was flashing my bright. gh3y
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 08-27-2006, 11:42 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Stock PM6 blinks one for one... so code 17 would be like dude said.. 17 blinks.. I got a 16 for the longest time b/c of a shorted ground... (INjector wiring/faulty injector)
Anyway, if you take your car to your local autozone, they can hook up the baer machine and test your electrical system for free. I suggest that. It tests the charging/starting circuits... if it comes out good, have them run it one more time, and depress the brake pedal when the guy asks you to rev to 2k rpm (at the same time as you're revving) it will put load on the charging system if there's a short, and that will tell you the problem.
Good luck.
Old 08-28-2006, 01:18 AM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
The first easy thing to check is all of your double filament brake light bulbs. Look for a broken filament that has jumped over to the tail light filament. Every time you step on the brake the short circuit feeds back to the dash.
Old 08-28-2006, 05:12 AM
Get it?
hey sorry never had to check codes on a stock car.
but thanks for the info. i never knew that.
-tony-
2000 honda s2000
Old 08-30-2006, 01:28 PM
as a matter of fact, i dont know if this would have anything to do with it, but my left taillight IS more dim than my right. it was like this when i bought the car, but this problem was never occuring. could it have something to do with this problem?
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 08-30-2006, 02:36 PM
You should take your tail light apart and check it out. It's not hard to do. Better to fix something easy than to be stranded on the side of the road with a dead car...
2010 Honda CR-V EX
