Old 08-17-2006, 02:21 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: Manual Shifting an Auto...
i dont think its made to hit 4th on the tracks..cuz its what it is, 'overdrive' not 'drive' its just to give you gas mileage
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 08-17-2006, 02:52 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
MmmHmm.. Overdrive is too weak in any transmission to be hot-rodding, IMO..
EDIT: I've always wondered..Why not make OD a 1:1 ratio, and just change the rearend gearing. I've always been taught that any overdrive generates more heat, transmission or otherwise... Opinions?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-17-2006, 11:36 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
You guys do know when you place a gear indicator in Overdrive it isn't actually in that gear til it hits that shift point, right?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-18-2006, 04:00 AM
gear indicator?
Car:
285's in the back
all else = STOCK.
Old 08-18-2006, 04:19 AM
Yes...I don't speak for others, however.
Old 08-18-2006, 04:23 AM
*brain farts* wait, you mean gear indicator as in when the stick is in [D] right? cuz i knew that.. lol
Car:
285's in the back
all else = STOCK.
Old 08-18-2006, 05:11 AM
FormulaLT1's Avatar
Fight the powwa!!!
Yeah, thats what I meant. Overdrive is what the car should always be what the car is in unless you don't want it upshifting to that gear. Under WOT conditions the car will run out 3rd gear anyway, so there is no difference if you had it in overdrive or plain old drive.
Old 08-18-2006, 09:46 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
I would say that you would want to shift the 700r manually. Your transmission will want to shift into second before its time because of wheel spin. So your basically trying to pull from 2nd which doesnt work very well.
I wouldnt think that you could top out 3rd. I have about 2 to 3k rpm more to go at the end of the quarter with 3.23's. I would just hook up a different tach to your car to make sure that the stock one is accurate if you have a thirdgen because they are known to be off. I'm actually working on a write up that I was going to send to formula about how I fixed my tach because it was saying that I shift at 6000 when it was actually around 4500.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 08-18-2006, 02:04 PM
jmj_camaro jmj_camaro is offline
shift kits are designed to give you more solid quicker shifts they wouldnt have any effect on the od problem. to be honost i wouldnt try to use od while racing there is a lot less to this gear compared to the other three and will go out a lot faster. unless you feel like replacing trannys left and right. which if you have that kinda money then you might consider these options. one change the gear in the back to a higher gear. you wont have as quick of a take off but you will get more out of the gears you got. or two have the tranny rebuilt with new first and second gears that are longer so you wont have a chance to rap out in third. or just get a manual!!! theyre a lot more fun anyway.
Old 08-18-2006, 09:43 PM
TEXAS-HOTROD TEXAS-HOTROD is offline
The LT1 Camaro's tranny is a 4L60-E, it's fully electronic. It shifts when the p.c.m. tells it to. The third gen's tranny is the old 700R-4 (4L60) which uses the t.v. cable (kick-down) to control operations.
IROC and Corvette 700R-4s had a different valve body and do shift into 4th gear at w.o.t. to obtain high speeds (intended for road racing). The Camaro/truck/car version will always have a forced down shift into 3rd at 2/3 throttle. The early stages of the dreaded speed limiter. The only way around that problem is to set it up as a manual shift, then it will shift into what ever gear you put it in.
Topped out at 90mph in 3rd gear, are you sure? What gears do you have? 6K rpm at 90mph would have to be at least a 4.20/4.30 gears. It might be red lined in 2nd at 90, but no way in 3rd.
To answer your original question: Yes, pull it down into 3rd if you're playing around or racing. Let the computer/tranny do the work and concentrate on driving the car. It also activates an additional forward clutch pack in the tranny when it's in "D", so there's less chance of slipping/burning the main forward pack. Also the pcm learns your driving habits and tunes (sort of) the car to you. I have heard of people disconnecting the battery over night, reconnecting it, and then driving the car aggressively. They said that the car performed better. Then again, with o.b.d.2 electronics, the battery shouldn't be disconnected unless only necessary. So you might check into that more before trying it.
It is a fact. A car with tall gears (3.42:1) will always be faster than the same car with low gears (4.56/5.30:1) that uses an over drive gear at mid track. An over driven gear uses torque to send torque, so it's less efficient than a 1:1 gear.
The taller gears might be slightly slower out of the hole but will always be faster at the top end. Running that short of length at that slow of speed in an over drive gear will slow you down.
Old 08-20-2006, 04:24 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
If you want to rebuild your tranny often, then you should let it shift into 4th gear at wide open throttle.
Same reason you don't want to shift into 5th gear at WOT in a M6.
Don't shift into any gear lower than 1:1 at WOT.
Corning...while you may get higher RPM's if you manually shift, I bet you are a touch slower doing it yourself. The cars programming is set up at the optimal shifting points.
Unless you are modded a bunch.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
