Old 08-21-2006, 03:36 PM
sdsniper's Avatar
sdsniper sdsniper is offline
Talking Re: 91 Firebird almost done fixing needs some more help
Originally Posted by wrightz28
Those wires are the IAC -idle air control and TPS, throttle position sensor, and without either, things will not work correctly.
Do you think i should cut the wires and fuse them together some how?
Thank You to everyone thats helped me. I really appreciate it. Thank you!
Old 08-21-2006, 03:49 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Soldering is the approriate way to repair a wire, however, cince these are wires related to the ECM I would say no in this case as it may add resistance to the circuit and hamper the ECMs interpretation of the circuit condiiton. Maybe use a butt connector?
I'm not that versed in this area, so hang on and see if someone else a little more electric saavy can tell you a get around.
Old 08-21-2006, 07:32 PM
sdsniper's Avatar
Thanks for your suggestion. I think that might work but yea ill wait for some other incite.
Old 08-22-2006, 02:13 PM
sdsniper's Avatar
so my choices are sodering them back together or using the butt connector.
Old 08-22-2006, 02:26 PM
wrightz28's Avatar
I'd use the connector if possible. it the damage is really close to the connector making it difficult, then I'd splic in a new. Again, soldering ECM related circuits can leadc to problems and more damage if not done correctly.
Old 08-22-2006, 03:33 PM
sdsniper's Avatar
I was just looking at the chewed wires and yea they are really close to the connectors. I would have to splice a new wire in there. Sounds like a good idea. Im going to make some phone calls and see if this method wont risk my car catching flames because of the wires shorting or something. Hopfully not because this really sounds like the easiest way to do the job and get my engine running.
Thank you :-D
Old 08-22-2006, 03:44 PM
wrightz28's Avatar
Even if you only use crimp style butt connectors and electrical tape instead of heat shrinking how in the bejeezus is you car going to explode?
Old 08-23-2006, 01:38 PM
sdsniper's Avatar
Well i figured that because the fuel injectors are right there and if there was ever a spark or anything. ya kno but im sure that wont though. Just being cautious.
There isnt any certain type of wire i have to use to splice these bad boys together?
Old 08-23-2006, 01:41 PM
wrightz28's Avatar
If you putting new sensor pigtails on, the wiring is already included
Old 08-24-2006, 10:18 AM
sdsniper's Avatar
ohh yea i should just get new sensor pigtails from a junkyard or dealer because the ones i have now are chewed pretty close to the connectors. now i know what you meant. i was thinking about doing it diffrently but that seems easier. Thank you ill try it :-)
Old 09-03-2006, 02:47 AM
sdsniper's Avatar
welll haha i spliced the wires together and my car blew up..no just KIDDING :-p
So, i did splice them together. The car still wont start. So i figured out again...what the problem is haha...I disconnected the fuel filter and turn the key not until its starts but just so it turns on the cars electrical. I did this so i can check if a stream of gas comes out from the fuel line. There was nothing...I have a bad fuel pump :-( so it should be fun fixing this yikes
