| Latest | 0 Rplys |
WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
#16 | |
Re: 1999 Mitsubishi Eclipse GSX full custom street and show monster
I like the progress, did that turbo come with that kit or is it an aftermarket one? I'm also feelin the cams!
#17 | |
![]() Join Date: Nov 2005
The turbo comes with the Fujimi Hi Mechanism 3.0 Supra.
![]() ![]() Glad you like it...
![]() Slow down, dear, you're scaring the dog... 1:1 ride: '84 BMW 318i, needs attention. Stickin' with it ![]() 1:25 450+ hp DSM build, Click here for thread ![]() |
#18 | |
![]() Join Date: May 2005
If you want a turbo that would produce 450 horsepower or more your going to need a lot more than a 16G.Put something large on there and be done with it.
#19 | |
450 doesn't sound too unreasonable for an Evo III 16g. A Schwitzer S200 would put me dead into the 400-500 hp range, but then again that is where it is designed to operate. And can you say lag? Although, technically, this isn't really a 16g, since I'm using the TN external wastegate, whereas the 16g's utilize internally gated turbos. Yes, the turbo shown has the wastegate actuator, but I'm lopping it off when I get the cast piece finished. Also, look at the size of the thing, it's wee bit bigger, it almost spans the block!
Uh oh... which makes me wonder: will the alternator and P/S pump fit now? Hmmm, must go look... ![]() ![]()
#20 | |
Very cool project so far! I'm loving the attention you're giving each and every part. It should be a stunner!
The name is Sam.. and I'm ready to rock ------------------------------/ ![]() TRIUMPH! |
#21 | |
Thanks!
Well, the bodywork is now on hold, I've decided it will be too much trouble to repair. When i first cut open the doors a year ago, on the drivers side I also cut out the window rubber, thinking it was part of the door frame. ![]() ![]() I'm probably going to get another kit, that way I can cut the doors and hatch with string (much better method, I think), glue the mirrors on AFTER I get the doors cut out ![]() Meanwhile, I'll be practicing with the leftovers to get the door jambs right ![]()
#22 | |
Guest
Posts: n/a
Never been a fan of the eclipse but i love the work that you are doing..hope to see this baby finished.
#23 | |
No luck finding a new one yet, waiting on Walmart... nearest LHS is 70 miles away...
![]() Some teaser pics of the PS2b, I'm not satisfied with the body, so I'll probably redo that, it's made of .005 and .020 sheet styrene, a little thicker than it should be, but that's about as close as it's gonna get. The two "buttons" are just melted plastic that leaked out when I clamped it down, but they are about the right spot! I might make the disker drawer open with a PE disk in place, add some realism. Or if I leave it closed, I'll try and get some screen shots of NFSU2 or Carbon and make decals for the screens ![]() ![]() Here's the controller and cord, there will be 2 of them hooked up. I'm going to recast better controllers with more detail and detail paint the buttons. And boy are those controllers big... ![]() ![]() Where do you guys think I should have it? Originally, I was just going to leave it in the passenger footwell, but that seems a little unfinished for a car like this. Under the seat would just hide it, and sticking it the dash would only show the front... Maybe I could mount it to the underside of the dash, shave the glovebox? I'm open for ideas...
#24 | |
You're gettin crazy.
http://www.bhop73.com/ |
#25 | |
![]() Join Date: Jul 2002
Looks good so far, I had the same problem a year or so ago when I tried to open the doors and such on my revell ITR... luckily I had an extra kit to steal to body from.
#26 | ||
![]() OK, here's the second attempt at it. I painted the first to see if it would look OK, and then I smudged the paint and it gummed up the fins. So... Measured and cut the piece more carefully, also spread the glue very thin. Ended up about .010 thinner than the first try. The picture shows the pieces left to right as they are assembled top to bottom. The fins are made of .005 styrene (9x6 mm large, 8.5x5.5 mm small) and the last piece is .020, 8x5.5 mm. ![]() If anyone else builds one of these, make sure you spread the glue, I used a .010 strip and some Ambroid. The first time, the glue built up in the center and made it too thick, and also melted through to the top layer, giving it a nice dent. Here's take 2, sorry for the lousy pics: ![]() Here's the dash, you can see where the TV will go, the shaved radio (to be replaced with a PE stereo and maybe and EQ), and the shave handbrake, I'm relocating it to the correct position using the piece form the AMT Eclipse. The PS2 is the white chunk. I wanted to slide it under the screen until someone told me the top of these open instead of having a disk drawer (you can tell who doesn't play video games ![]() ![]() ![]() EDIT: Suppose that last pic would help: ![]()
#27 | |
![]() Join Date: Jan 2005
Better and better, NIce Talon. ; ) lol
#28 | |
![]() Join Date: May 2006
Try ebay, I just got a 3 fast and furious kits, 2 supras and the eclipse for 9.99.... Shipping was 3 days too. Just trying to help, lookin good man.
#29 | |
![]() Join Date: Jun 2005
Man if you can I reakon you should open up the glovebox somehow and mount the ps2 in it. And if you feel like being really detailed on it. You should open up the disc drive bit of the ps. That should look frigin awesome!
BTW. Everything else looks real good man. Nice detail. |
#30 | |
Wonderfull Work.. I loved the PS2
![]() http://www.minituner.com.br WIP: Project NoMother (Nomad '55)**UPDATED (09/02/2005) My Mustang Boss 429 (Completed) My Mercedes Benz CLK DTM 2000 Street (Completed) |
