Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 08-05-2006, 08:52 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: Help I dont want it to DIE!!!!!!
Royal Purple's Purple Ice i think is a good one.
ZedEx Crew Member #4
Old 08-25-2006, 06:27 PM
masood masood is offline
Send a message via ICQ to masood Send a message via AIM to masood Send a message via MSN to masood Send a message via Yahoo to masood
check the thermostat also. you can find a 62C one at www.mynismo.com that is about 35 F less than the stock one.
Old 09-19-2006, 07:14 PM
subl1minal subl1minal is offline
i just went through a lot of overheating problems with my car after i did the intercooler and electric radiator fan. the original one the shop decided to put on was a 2000 cfm single fan with no shroud. didnt' cut it. so i had him return it and i bought a dual fan Flexalite ultrathin with the shroud that seals against the radiator core. i then flushed my system and added almost 90% water instead of antifreeze, and i can now run 8-9 psi all day in 105+ weather with no overheating problems. and that's with an intercooler in front of the radiator! so yeah your fan is most likely the problem, as you say you can stop it with your hand. haha so just go with an electric fan... more piece of mind, better cooling, and a little more power!
'87 Z31 Turbo- JDM FMIC, Flexalite ultrathins, 2.5" pipe w/ no muffler, mbc @ 9psi, HKS SSQV BOV
Old 09-19-2006, 07:20 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
you're only running 9 psi? you can safely run 12-13 easily with the intercooler in there... also a good idea would be is to run shrouds from the intercooler to the radiator on the top and sides as to direct air at the radiator when moving at speed..
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 09-20-2006, 10:30 PM
yeah i took the plastic shroud off by the oil pan and cut it to fit in the front under the bumper lip. it fits perfect can you really run 12-13 psi on this motor safely? i thought it might punch a gasket or something..... and man do i want to swap it to a 5 speed now. the stock auto trans blows so hard. it actually slips when i come on boost when it shifts from 3rd to 4th gear. pos.
Old 09-20-2006, 10:33 PM
DeleriousZ's Avatar
shit dude where have you been... you can run up to 500hp on stock internals on these motors... the only reason you don't want to run more than 15 psi on the stock turbo is the injectors max out and you're out of the efficiency range of the turbo.
the oem head gasket from nissan is more than strong enough to hold that amount of power as well.. just make sure you run 93+ octane
Old 09-20-2006, 10:36 PM
shit. f'in california only runs 91...... how much boost should i technically be able to run with 91 octane? and yeah haha i'm kinda new to this forum. so i haven't read up on the motor that much.
Old 09-20-2006, 10:39 PM
DeleriousZ's Avatar
that depends... i'm assuming you have a manual boost controller... so a good thing to do is turn it up to 13ish psi and if you have an a/f gauge on it keep a close eye on that, or a REALLY good ear out for detonation... if you get any inkling of detonation back the boost off 1 or 2 psi...
the best thing to do would be to get ahold of some octane booster
Old 09-20-2006, 10:42 PM
good idea. i have a good ear for engine noise so i'll check it out and listen for knocking. as for octane booster, i thought the stuff they sell only raises teh octane by like 1/10 of 1 octane?
Old 09-20-2006, 10:50 PM
DeleriousZ's Avatar
yeah i'm not too sure, you could also read up on people who use tolutene as octane booster... apparently it works pretty well
