Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-08-2006, 11:55 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Running water sound
Leoman will prove to be correct on this one. The running water sound is air in the heat core and related lines. You need to get the air out of the cooling system to eliminate the noise, and more importantly, make sure you don't roast the moder.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-08-2006, 01:06 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
'92 3000gt SL
Zoom Stage 1 Clutch
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-08-2006, 01:52 PM
ned032002's Avatar
ned032002 ned032002 is offline
Originally Posted by Cain98Eclipse
Yeah I have tried aiming my vents? ASS!.
Hey it's the thought that counts.
Old 07-08-2006, 02:57 PM
Cain98Eclipse Cain98Eclipse is offline
Send a message via AIM to Cain98Eclipse Send a message via MSN to Cain98Eclipse Send a message via Yahoo to Cain98Eclipse
Originally Posted by ned032002
The reason that you are hearing water is because the drain is plugged and to un-plug it, put the nozzle of an aircompressor up to the drain which is on the fire wall on the passanger side (near where you are hearing the water). When you blow the air into the drain line, it should un-plug and you should have water pooring out.
I am not seeing a drain on the fire wall of the passanger side could it be anywhere else? And I know its the thought that counts, but that was just mean to assume I am that stupid. Im not the smartest person in the world when it comes to cars (as everyone can see) but I do know how to aim vents in the car.
Originally Posted by loeman
Sometimes a lot of air in the cooling system can sound strange as it comes through the heater core, so go to MY "overheated thread" and follow the proceedure for eliminating air bubbles in the cooling system.
I looked at this and I will try this after I find the drain if that dont work.
Also still having trouble with my dash lights, I have never seen this before in any car. When I turn my lights on my dash lights should come on, but they dont. And the CD player will come on and off, on and off unless I put it on the radio then it will stay on untill I turn my lights on. Then it will go off, it does not keep memory (time, what station I was on, ect.). When I shut my car off and leave it over night the next day I have to turn the cdplayer back on and then back to radio. It dont bother me that bad seeing how I drove 4 years before this car without a cdplayer or radio, but I need my dash lights so I can tell how fast I am going. If I dont look at my speed I tend to drive a little to fast. And I am still on probation from where I just got my license back not long ago, and have to controll my speeding.
I have check all the fuses in the car. Also check the battery, and pulled the cdplayer out to see if it was hooked up correctly. I dont know what else to do but to take it to a shop to have it fixed, and I really dont want to do that if I can fix it myself. (No jokes about me obviously not being able to fix it myself please. I mean when I know whats wrong.)
Car: 98 Eclipse RS NT
Mods:
AEM Cold Air Intake
Megan 4-1 header, downpipe, and testpipe.
Megan Cat-Back exhaust 2.5" with 4.5" outlet.
Future Mods: Everything I can do to make the car faster and look better!!! But all I have is Im so poor and thats about it
Old 07-08-2006, 06:24 PM
ned032002's Avatar
I was just kidding about the aiming of the vents.
Did you use a wiring harness when you installed the cd player or did you hard wire it in?
Old 07-08-2006, 11:22 PM
I didnt install it but they used a cd harness when they installed it.
Mods:
AEM Cold Air Intake
Old 07-08-2006, 11:37 PM
SLoe's Avatar
SLoe SLoe is offline
I've never messed with a NT car, but it doesn't matter. You are looking for a tube hanging down from the firewall in a manner that it won't drip water on anything The tube will be on the passenger side, and it will prolly be coming from the condenser, since that is what it was meant to drain.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-10-2006, 11:49 AM
SLoe's Avatar
Hey man, did you get your stuff fixed? Did you try turning the pot. on the dash lights (you know the knob that makes them brighter)?
Old 07-10-2006, 04:33 PM
ned032002's Avatar
Loeman your as bad as me now hes gonna get pissed at you and call you a "ASS" may the force be with you.
Old 07-10-2006, 08:20 PM
SLoe's Avatar
Me?? No way! EVERYONE LOOOOOOVES me
It could happen........right? You could accidentally turn that knob and not know it.
Old 07-10-2006, 08:32 PM
Yes I have check the knob...I havent had time to try and find the plug yet I will work on that wed when I get a day off. I will post my results that night.
Mods:
AEM Cold Air Intake
Old 07-10-2006, 08:46 PM
SLoe's Avatar
Cool
The force is strong with me Neddy baby.
Old 07-12-2006, 07:48 AM
ned032002's Avatar
Please never use the word Neddy and Baby in the same sentence...please.
Old 07-12-2006, 11:15 AM
SLoe's Avatar
Old 07-12-2006, 12:12 PM
Ok I went looking around my car while I had a little free time today, and here is what I have found. This is the only tube I could find and it was behind the fender of the passenger side I couldnt get a air compressor because my friend had to work today and my little one I use in case of a flat would not work for nothing. LoL Can you tell me if this is the one, because on another site I found a guy was having the same problem as me and they told him that the tube was on the drivers side of the car I jacked the car up and had a look around but couldnt find anything on the drivers side unless it is also under the fender but I didnt have time to take it off. Im going to use my friends compressor on the tube in the pic above unless told other wise by Saturday.
Thanks for all the help so far. Sorry to be such a bother.
Mods:
AEM Cold Air Intake
