Go Back   Automotive Forums Car Chat > Suzuki > Aerio/Liana
Old 01-25-2004, 08:00 PM
DannoAerio DannoAerio is offline
check out suzukiaerioforum to see the solution to this problem. A user there has posted wiring information to deal with the DRLs.
Old 08-25-2004, 09:27 AM
kidfam kidfam is offline
Reason for wanting Daytime Running Lights Off
My reason is that at night they are on, but not the tail lights. Many times I forget to actually turn the headlight switch on cause the lights are already on. Luckily no accidents yet from being rear ended because someone couldn't see my ass end.
Old 09-13-2004, 09:42 PM
maceyr maceyr is offline
Check out Aeriostyle.com
http://www.aeriostyle.com/forum/viewtopic.php?t=84
Old 10-18-2004, 11:00 AM
Re: how can i turn off the daytime running light???
I want them OFF on my Aerio SX too because too many nights the lights are already on and I forget to turn the headlight/tailights on. NO HEADLIGHTS on means NO TAILlights on.
Old 11-13-2004, 01:40 AM
Evo6 Evo6 is offline
You cant turn them off.They turn on automaticly.Though you can do a light conversion.
Old 12-03-2004, 07:05 PM
DRLs
I hate them!! Too many times driving away at night you forget to turn on the headlights which includes TAIL LIGHTS. Dangerous feature, Someday I expect to get rear ended because of this
Old 02-17-2005, 08:08 PM
benson_pedro benson_pedro is offline
The answer to your prays
Open your glovebox and pull it down past the rubber stops. Look up and to the left and you will see a silver box with a wire harness plugged into it. Unplug the harness. That's it.
The only other function that becomes disabled is the little dummy "BRAKE" light that comes on in your dash when you pull up on the parking brake. But if you want to see that light for some reason, you can add a jumper wire to the red/black wires inserted into the harness. The 2 blue/white wires are for your headlights, while the other 4 red/black control your brake lever light.
But without cutting wires, or splicing anything, this is the easiest method for disabling your DRL's, and can quickly be converted back to stock in less than 30 seconds.
Old 07-14-2005, 04:34 PM
gatopanzo gatopanzo is offline
amps and alternators
so how much power can the stock alternator handle because iam thinking of putting in a system and would like to replace the alternator to something a little stronger then.
Old 06-14-2011, 02:30 PM
Valery Shal Valery Shal is offline
Banned
ok so whats the main problem about that ? i mean why do u waana do that ?
Old 06-20-2011, 12:39 AM
drls drls is offline
If the switch is installed, turn it off, if not, the DRL will remain lit untill the car engine switched off
How to turn off the red blinking light (led) on my radio wzblazer TrailBlazer | Trailblazer EXT 6 02-08-2006 01:53 AM
98 Blazer..How to turn off Day Time Running Lights? alpineblazer23 Blazer 12 01-31-2005 08:59 PM
How to turn off the check engine light? panther4417 Accord/TSX/Accord Hybrid 12 11-05-2004 09:47 AM
how do i turn off the check engine light? madmaniac '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 02-21-2004 05:29 PM
How Do you turn off the daytime running lights on 02 cavalier? yellowcav Cavalier 4 02-06-2004 10:45 AM
