Old 06-27-2006, 02:35 PM
goser goser is offline
Re: Flowmaster
Originally Posted by wolfox
A FloPro is the most free flowing of them all, however, in our application the most I would venture to put on the truck would be a 750 with center inlet, offset outlet. (2.25" dimater tubes) This is bbout as close as you can get to the absolute edge without harming anything else; flow better than stock and save some dough while doing it. It maintains a token amount of backpressure so heads/valves stay cool, EGR does it's trick, O2 is metered properly and the ECU stays happy without tossing codes. And that's my . I got an immediate 11% gain in MPG with my muffler setup before I opened up and modded the intake to match it.
Forgive my ignorance, but what is a "750," and where would it fall in flow rate compared to say the flowmasters and ravins? Is that the muffler setup you're running?
Old 06-27-2006, 03:03 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Flowmaster
The number is just a model number indicating mostly inlet/outlet size, position of those pipes on the body cannister and relative flow rates. FloPro gives numbers to subsets of products with names. (I.E. FloPro Turbo 400, FloPro Twister 530, etc, etc. Mine is a straight, no nonsense oval FloPro 750 with an intererior, single baffle design that's seam welded)
Where it fits in as far as flow rates? 1st, really - followed by Ravin by a very close margin to be nearly identical, really - and then Flomaster at roughly 1/3 less flow rate. If you ever bought the complete FloPro kit in a box, there is a sheaf of paper with installation instructions and the flow charts based on a static water supply flowing through the muffler's innards vs other popular brands. Why they use liquid for testing instead of gas is a little of a mystery to me, but understood - as I use dynamic liquid simulation software to gage and design stuff that flow gasses.
Old 06-27-2006, 07:34 PM
TheBrettster TheBrettster is offline
AF Premium User
Re: Flowmaster
you dont want free flow cause you loose all your low end torque
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
Old 06-27-2006, 08:35 PM
98BlackTransAm's Avatar
98BlackTransAm 98BlackTransAm is offline
Send a message via AIM to 98BlackTransAm
Re: Flowmaster
true you do lose some low end torque, but what it does is shift the power curve of the engine to the right, and in the end you'll have more torque in the higher RPM's and it will net you quicker 1/8th and 1/4 times.
2002 Firehawk (M6) http://www.youtube.com/watch?v=6XKnrV7c_Bs
F13 cam (230/232, .595/.585, 112+4 LSA) | PRC Dual Valve Springs | LS2 Timing Chain | Ported LS6 oil pump | Pacesetter LT's | TSP catted y-pipe | Flowtech cutout | LS6 intake | SLP lid | SLP cat-back | Bilstein suspension | Tuned by Mayhem Motorsports
1998 Pontiac Trans Am (A4) - SOLD
slp lid, pacesetter lts, ory, flowtech cutout, fuddle 3400 stall, B&M tranny cooler
Old 06-27-2006, 11:03 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Flowmaster
Originally Posted by ZL1power69
cherry bombs flow good but kill ur gas mileage
Dude, Cherry bombs are not all glass packs.
http://www.supremeperformance.com/DisplayTab.aspx?tid=2
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-27-2006, 11:11 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Flowmaster
i always thought they were. thats how they are listed in jegs, summit, etc. if they aren't all the glass pack type, my bad.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 06-27-2006, 11:14 PM
BlazerLT's Avatar
AF -Advisor
Re: Flowmaster
Sorry, my reply might have a sounded a little abrupt, it came across wrong.
They are all made by Maremont.
Old 06-27-2006, 11:59 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Re: Flowmaster
So you can just use a universal design right? What are the specs, inlet/outlet, center/offcenter?
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 06-28-2006, 12:09 AM
BlazerLT's Avatar
AF -Advisor
Re: Flowmaster
Well, they will have to weld an extension pipe on it.
2 1/4" offset inlet, center outlet I think.
Old 06-28-2006, 09:14 AM
wolfox's Avatar
Re: Flowmaster
Some of those Cherrybombs are reversible, changing the way exhaust rolls over the louvres inside the body tube. One way, it makes a rich, mellow tone and nice growl at launch. The other way around does the same thing, but when you let off the throttle, it doesn't dampen the random ignition of unburned fuel in the pipes, making a nifty pop-a-pop-popity-pop as you decel from highway speeds.
I reversed a FloPro Turbo series muffler that was just a resonator can, similar to a glass pack on my Scooby with that 2.2 flat-4. Awesome sounding machine after all the go-fast parts went in, without a ricer fart pipe on the back end. It just sounded mean, and being all plain white, no pinstripes,stickers, nothing - quite a stealth sleeper. It scared folks when I would pull away from them @ WOT at lights, or playing in the sand/gravel where you have to snap the throttle for drift-like turning utilizing the built-in AWD.
Old 06-28-2006, 03:16 PM
AF Premium User
Re: Flowmaster
ehh i went with the flow master any. The speed shop down he recomended it and i got it for 65 bucks with a lifetime warrenty. If it doesn't work out then i can just buy a new exhaust.
Old 06-28-2006, 03:34 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Flowmaster
I think that I'm going to go with flowmaster, on my Blazer, too. I've already got them on my Impala.
I saw some tests a while back. If I remember correctly the Vortex flowed about 300 and had more horsepower. The flowmaster only flowed about 250, but had more low end torque.
Old 06-28-2006, 04:08 PM
BlazerLT's Avatar
AF -Advisor
Re: Flowmaster
That is probably due to flow restriction and backpressure.
Old 06-28-2006, 04:59 PM
AF Premium User
Re: Flowmaster
Nice i have one on my 95 Impala SS to
Old 06-28-2006, 06:03 PM
Scottm69s Scottm69s is offline
Re: Flowmaster
My flowmaster on my Blazer sets it apart from the rest. Get one.
