#16
Re: Overrevving 700R4s?
in my mind when i think of overdrive i think converter lockup. However this is not the case. I was really only partially messed up in my thinking. im not confused anymore since I came to the realization that im partially retarded.
so 4th is a gear and the lockup is just that. I dont know where I get this stuff from....
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
#17
I guess you're forgiven this time.
#18
i think you wouldnt want to be shifting through 1-2 by yourself..cuz it wont do anything different if you floor it in non-overdrive.
im pretty sure the car will redline the engine before shifting if the pedals to the floor (if its set up right..) so cycling through the gears yourself will probably give you a worse pickup..
Car: ![]() 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK.
#19
Dont matter if you prefer manual or not, shifting it on an automatic is just dumb unless you're going up hill or downhill or something different than trying to go fast.. BTW if thats what you meant.. then.. I just rephrased it.
yea, the tranny will shift faster by itself than with you messing with it
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
#21
back to this guys question , just get a shift kit so you can shift to any gear at any rpm.
95 Z71 Silverado 4x4 ext. cab Mods- Flowmaster Exhaust,Intake |
#22
well i am saying he could shift manualy, if someone decides to shift down past redline that is there own dumb fault.
#24
if a transmission is not making it to redline then manual shifting might come into play. But you still want a shift kit in there if your gonna do that a lot.
#25
It's better to pull it down into "D" when playing around.
There is actually an additional "forward" clutch pack that's engaged in that shifter position. So you have more clutches holding the additional torque when you mash on the go pedal. To go one step farther, when you shift down to 2nd position, the fluid pressure goes into "over-boost" mode. So you not only have more clutches engaged, you have more fluid pressure to keep things from slipping. Most auto trannys won't down shift if rpms are too high anyway. The governor won't allow a down shift that will over rev an engine. On aggressive drives (sport driving?) that we used to do, I would come flying up to a curve, hard on the brakes and pull down to 2nd gear (Turbo 350). It wouldn't down shift until rpm/mph was at the correct factor, then it would kick down and bring the engine back up, close to rev limit. Rally Sport has a good thought too. W/pedal-to-the-metal, the tranny shifts at max rpm anyway. So you probably won't gain anything by manually shifting, but it would be a good idea to at least pull it down into D anyway. We all know that over revving a stock TPI (or should I say an engine w/a stock TPI intake) makes you slower, so use your best judgement. Any kind of a shift improver is a good thing. If you're not being stupid, or something. As long as it feels good and doesn't make any harsh jolts (firm is good, harsh is bad) , shift it all you want to. I do. One more thing. I have seen the reverse drum in earlier 700R4s baloon out from over revving. The later (1988-up) units do hold up well. |
#26
...hmmm.....thats very interesting. I didnt know about the additional clutch pack and overboost thing....cool.
