Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-07-2006, 02:38 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 20g or t3/t4 ?
I personally only run FIC, since I've had such good luck with them.
Again for the archives, since this forum can be searched, base pressure (hose off) for a 1g is ~37-38, and 2g is ~43psi). Pressure with the hose on will vary from car to car, so that 33 psi figure above may not be accurate. Divide idle vac by 2 to convert from "hg to PSI, and subtract that number from your base (hose off) pressure.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-07-2006, 02:42 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 20g or t3/t4 ?
I just pulled that off of Mitchell quick just to get some rough starting point numbers out there.
95 Talon TSI AWD
97 Eclipse GST
Old 06-07-2006, 02:44 AM
AF - Advisor
Re: 20g or t3/t4 ?
That number will be pretty close with stock cams, since idle vac will be 18-22 "hg. Probably why they listed it at 33. I have no idea what it will be on a built NT motor though.
Kevin Jewer
Old 06-07-2006, 02:49 AM
Re: 20g or t3/t4 ?
You made the same mistake I did right away. He's not running a NT, he's got a GST.
95 Talon TSI AWD
97 Eclipse GST
Old 06-07-2006, 08:11 AM
AF - Advisor
Re: 20g or t3/t4 ?
Oops, getting my threads mixed up. They all look the same at 3am I guess.
Kevin Jewer
Old 06-07-2006, 12:39 PM
SySt3mR00t SySt3mR00t is offline
Send a message via AIM to SySt3mR00t
Re: 20g or t3/t4 ?
yupz .. its a gst ... and there not stock cams ...
96 GST
