Old 06-15-2006, 04:40 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: Does and donts
Originally Posted by nickledimed
ohh and wd-40 is considered a dry lube, rust and water retardent. but i do agree, some things require a dry lube.
Never heard that.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 06-15-2006, 07:37 PM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
Re: Does and donts
WD-40 stands for Water displacement attempt number 40.......
dont use it for EVERYTHING and ANYTHING it just helps with many things
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
Jasper engine, Rebuilt tranny + rearend
04 Pontiac Grand Prix GT
43,000 miles
Old 06-15-2006, 07:47 PM
RJ MALIBU's Avatar
RJ MALIBU RJ MALIBU is offline
Re: Does and donts
Do check your light bulbs once in a while.Also when you change bulbs like headlamps, brakes, signals, replace Both sides .Thats why they come in 2 packs
1997 Blazer w/99+front end with clear Euro Projector Headlights and parkinglights and cai 2 -12'' Dual subs 600w RMS 600 watt kenwood amp Sony head unit
2003 malibu-bone stock(wife's car)
Old 06-15-2006, 10:44 PM
Cruize Cruize is offline
Re: Does and donts
I think somewhere in the door bushing posts, someone said to lubricate the pins and bushings on a regular basis.
How does one clean the MAF?
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Old 06-16-2006, 07:20 AM
Re: Does and donts
http://www.automotiveforums.com/vbul...ensor+cleaning
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 06-16-2006, 08:25 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Does and donts
DO NOT USE ANY SORT OF STOP LEAK! This will usually lead to more problems.
Old 06-17-2006, 01:58 PM
wilfie27 wilfie27 is offline
Re: Does and donts
I just made the connection.....I added some tablet style stop leak a few weeks ago and last week the bearings in my water pump went out.
I then did something I'm not too proud of but I installed a forward flow water pump on my reverse flow system. Got too hot....coolant running against diaphram of thermostat, wouldn't open. Temporarily fixed by removing thermostat, but will replace with correct water pump before too long.
94 Firebird: 3.4L 220,000 mi
95 Blazer: LS 2DR/2WD 210,000 mi
96 Trans Port: work in progress
97 Silverado 4X4 Ex/cab: 200,000 mi
05 Malibu: 98K mi
08 Chevy Van: Direct TV work van
Old 06-17-2006, 06:30 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: Does and donts
Originally Posted by Ultrashock
Do use WD-40 for everything and anything or 3-in-1
WD-40 is NOT a lubricant.
Old 06-17-2006, 09:41 PM
Re: Does and donts
Don't run your gas tank too low.
1. The mechanic who inspects my Blazer said that one of the two main reasons for fuel pump failure is running the tank empty. The gas in the tank keeps the fuel pump cool. No gas = no cooling = pump eventually burns out.
2. My Blazer wouldn't start after I shut it off. There was enough fuel in the tank to keep the engine running, but not enough to get it started.
Cruize
Old 06-17-2006, 11:12 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Does and donts
do check your battery connections once and awhile to make sure they are secure. i had my positive come loose last month so truck would not start. do have tools with u at all times . that was my aloted pickle for that day .
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 06-18-2006, 11:26 AM
RJ MALIBU's Avatar
Re: Does and donts
Don't use Fix-a-Flat. Keep some tire plugs and an air compressor in the vehicle.
Old 06-18-2006, 02:55 PM
Ultrashock's Avatar
Re: Does and donts
yea but 3-in-1 is a lubricant I do believe
Fix a flat works great its just not a permanent fix (in my opinion)
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
43,000 miles
Old 06-19-2006, 12:49 AM
rental blazer rental blazer is offline
Talking Re: Does and donts
they also come in 1 packs for the idiots
