Old 06-08-2006, 09:12 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Connector
With his luck it will probably be on the PCM feed side of the connector. But if it is the side to the ICM/Coil Packs/CKPS I wouldn't mess with just the connector. He could replace the complete Y wiring harness with connector intact. I see it only goes to the ICM/Coil Pack connector and the crank position sensor, therefore can be replaced in its entirety.
BTW - Something had to cause the wiring damage unless he did it accidently or unknowingly.
Sounds like a trip to the boneyard would be a lot cheaper to me.
Note: That Y wiring harness has the infamous single ground wire that connects to ground on the ICM/Coil Pack module.
Timeslip 08/12/06
AF Community Guidelines
Old 06-08-2006, 09:37 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Connector
Good point Bob.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-08-2006, 10:02 PM
Liljay2003 Liljay2003 is offline
Re: Connector
yeah the burn is on the PCm side of the connector< i noticed it when i got my DHP PCM and i didnt know where it lead to into last week so its been like that for a while since feb 06/ so i'm tryin to replace it now< i dont know how it got that way or how long its been< I may have done something or have it been like that since i got the car in 03 < so i really need is the Connector and one wire that runs to the PCM with thoses Pins to put in the PCM connectors < it was only one wire Burnt like a orange/black wire it looks like>
Old 06-09-2006, 09:19 AM
BNaylor's Avatar
Re: Connector
Do you have a better pic showing the damage?
Where exactly is the damaged orange/black wire and how bad? Is it right at the connector or where the wiring comes in/out of the connector? You may be able to field fix it by repairing just the damaged portion of the wire.
Also, have you disconnected the connector and inspected for any damage, arcing at all pins? The connector has a safety tab that has to be removed first. I just cut mine off and trash it.
Timeslip 08/12/06
Old 06-09-2006, 04:42 PM
Re: Connector
the Damage Goes from to PCM and leave a burn trail to the connector< I Wrapped some wire around it to Temp(replacement) intil i get the parts to do the repair But from the looks of it the connector inst damaged just the wire< i havent took it off< b/cuz i dont wanna damaged it anymore intil i get the parts to fix it you know< but the other side ot the connector isnt damaged at all<
Old 06-09-2006, 05:18 PM
BNaylor's Avatar
Re: Connector
How much of the orange/black wire coming out of the connector is undamaged or is it damaged right up to where it inserts into the connector?
Timeslip 08/12/06
Old 06-09-2006, 08:40 PM
Re: Connector
Yeah its all the way to the connector< it was on holding together at the connect by two threads or wire< but i wrap it up with wire and electric tape it look new, but i know better. Like i said it just holding together so i can get the part< i'm going to change those plugs tomarrow> I got those wrenches you have but i guess the only prob now is the 100 deg heat tomarrow>
Old 06-10-2006, 02:34 AM
BNaylor's Avatar
Re: Connector
It is hard to say on the connector but you can dismantle it and possibly splice in a similar grade wire (range of 18 - 24 AWG). Either way when you get the new connector it will be a PITA. Instead of just one wire you will need to connect 7. Of the 8 pins, 7 are used.
I see you are in Dallas so the humidity will probably be bad. I'm in El Paso and we hit over 100 a few weeks ago but our humidity is 20% or less. Have fun and good luck.
Timeslip 08/12/06
