#16
Re: I finally broke something
Why can't anything be easy...I hit a brick wall
That pipe connector that is sorta green, That is actually a short pipe connector between the fuel line and the rubber line. You can't just pull the line out of those, it may be built with it...I have no clue how to take that apart, or if I even should. HELP!!!
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
#17
Well...I was just thinking that if you found that stuff in the gas, then you also need to drop the tank, clean it out, and replace the fuel pump and fuel pickup/strainer(which could explain why you couldnt siphon the gas out through the fuel line)...
Once you have the tank out, it may seem easier to remove the fuel lines... |
#18
I need to think about this. What are the signs that I need a new fuel pump? Is it hard to drop the tank? does it take forever?
#19
Shouldnt take too long...
Dont you have a HAYNES MANUAL? If not, you should get one. It answers a lot of your questions with pick and tells you how to do this step by step. |
#20
What I meant was that the sand probably dammaged your fuel pump and it may need to be replaced.
#21
what is your email address? I can scan in the fuel tank stuff and email it too you and that should get you by for now...
#22
#23
The pump pumps the fuel through the fuel lines to the injection system.
If the pump is not turned on, then it probably wouldnt allow the fuel to pass through. Did you try puting a bucket at the end of the opening you created in the fuel line and turning the key to the on position(with battery plugged in)? This should cause the fuel pump to prime the system(meaning it would pump some fuel through the line). I thought this was how you tried to siphon the gas out... So try giving the fuel pump some power, if you hear the fuel pump working and if no gas comes out, then you have a problem, but if gas comes out then there is no blockage! If there is dirt in the tank you should still drop it and clean it because that would destroy the fuel injectors($50+ each)... i need to go, Il be back late tonight and I will check to see if you posted any more questions...bie |
#24
WHAT AM I SAYING?! I DON'T want to drop the tank...I'll sleep on it.
#25
droppign the tank shouldn't be that bad, all you've gotta do is drop the rear section of the exhaust and the rear, then actually getting the tank out I hear can be a bitch (due to the filler neck)
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
#26
2) not done...
#27
![]() That's no repro line, I found that on the end cap of aisle 5 in a Napa Autoparts. Talk about luck, 20 bucks, more line than I need but exactly what I needed, even has the O-ring!!
