Old 03-28-2011, 04:17 PM
big white bufflo big white bufflo is offline
Re: Snythetic Oil Question
i had trouble with synthetic i have a 97 f350 7.3 140000 on the motor i went synthetic and the motor leaked bad so i went back to normal shell rotelia and no more leaks
Old 03-28-2011, 06:21 PM
jyount jyount is offline
I had the same truck that had 125000 when I sold it. Bought at 69. Changed to rotella 5 40 synthetic at about 110000. No different except that sucker cranked up like lightning in the winter!
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 12-01-2012, 02:18 PM
tjfordboyesser tjfordboyesser is offline
i find the synthetic oils to work verey good and use them in all of my vehicles regardless of age or miles, for my ford vehicles i only use the motorcraft oil. i found that the recommended 5w20 that ford wanted me to put in my f150 was way to thin of an oil and made my engine run like shit after i hit 141,000 miles. i did some experimenting with oil mixes and found that 2 qts of 5w20, 3 qts of 15w40 and a qt. of lucas additive made my truck run alot smoother and with the use of a napa platinum filter i dont have to change my oil every 5k or 7500 miles. i change it ever 10k and it is only a light brown and not dark or black. im in the process of putting together an oil bypass system for the truck with a second filter that runs with the full flow filter but filters down to 2 microns. they use them on big rigs and it basically cleans your oil every 10 mins and you dont have to change your oil for 30k miles.
`55 ford f100 351w h.o.,`74 1/2 chevy k20 5.9 cummins turbo diesel, `86 dodge 600 convertible 2.2l, `87 ford mustang 460 big block w/nitrous, `89 plymouth hemi voyager drag van,`91 plymouth laser turbo drag car, `92 dodge caravan 2.5l turbo 5 speed,`97 dodge viper gts 8.3l v10 w/paxton supercharger, `99 mercedes slk-230 supercharged 2.3l, `01 f150 supercrew 5.4l, `05 f350 dually 6.0l powerstroke, `07 honda cbr 1000rr, `10 scion tc turbocharged 6 speed
