Old 05-22-2006, 10:48 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Replacing lifters...is it worth it??
Originally Posted by countrygirl22
Hey guys, thanks for all the replies. My Blazer was driven home after the mechanic had looked at it this weekend and about a mile from home it lost all power and the noise which we thought to be lifter noise became much louder. Could bad lifters explain the loss of power, or (much to my dismay) are we talking a lot more damage here then just lifters? It makes constant noise. When I first noticed it a while back it was more of a constant ticking noise. Now, it is a pretty loud.
That does not sound good.
Time to have a good look at it.
To check lifters or rockers you need to pull valve covers.
Also I would check oil pressure with a manual oil pressure gauge.
Have you got pressure?
And see if you can short out the noise by disabling one cylinder at a time.
A good trained ear can tell a lot from a noise.
Got any mechanic freinds that can listen to it?
Let us know how it goes.
MT
MT
Old 05-24-2006, 10:54 PM
Hunter1 Hunter1 is offline
I have never heard of a lifter causing a loss of power. Is it smoking at all?
Old 05-30-2006, 10:52 AM
countrygirl22 countrygirl22 is offline
No, it's not smoking at all. We haven't got a chance to tear it apart yet. But, when we do I will update you all on what we find out! Thanks for all the help!
Old 10-03-2006, 03:07 PM
Hey Guys!
Been a long time, but I finally got the Blazer back on the road. Turns out it was a bad lifter. After tearing it all apart we found the bad lifter (if I get a chance I will attach a photo)...it was pretty bad. The roller in the lifter was completely gone and took part of the casing with it. Only found a few of the pieces! A new set of lifters/$200 later and she runs like a charm! Sure saved some cash doing it myself rather than bringing it in.
Thanks for all your help!
Old 10-03-2006, 03:29 PM
MT-2500's Avatar
AF - Advisor
Hey Guys!
Thanks for posting back and letting us all know how it went.
Glad you got it going and all is well.
Good Luck
MT
MT
Old 10-03-2006, 07:16 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Hey Guys!
Aren't you meaning the rocker?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-03-2006, 08:37 PM
herkyhawki herkyhawki is offline
The stock lifters have a roller on the bottom that rides on the cam, the rockers are stamped, and do not have rollers, so it looks like countryg22 described correctly.
Old 10-03-2006, 08:47 PM
BlazerLT's Avatar
AF -Advisor
You are right, major brain fart here.
Old 10-04-2006, 11:18 AM
534BC 534BC is offline
How did the cam lobe "not get hurt" ? if the roller was gone?
Lucky if it didn't touch the lobe. A winner.
Old 10-04-2006, 12:10 PM
BlazerLT's Avatar
AF -Advisor
It might have gotten slitly scored, but I don't think it was run enough to seriously do any real damage. A lot of lubrication down there during engine operation.
One thing that shocks me is they never found the other pieces, but for some reason think they will be down in the oil pan.
Countrygirl...
Did you change the oil after this?
Old 10-04-2006, 12:18 PM
BlazerLT -
I did change the oil after everything was done. I did not check it though.
