Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-10-2006, 10:14 PM
dsm_dude12 dsm_dude12 is offline
Re: Consequences of breaking abalance shaft belt???
k so... what am i suppose to like the crank up with to se if its timed right? im reading in my hayne's manual that i have to line the 2 little marks on the top of the crankshaft pulley up with the t on the t-belt cover. and the 2 timming marks on the cam gears should be lined up if its in time. am i reading this right? or am i just an idiot?
1990 plymouth laser rs turbo, pace setter header, k&n intake. turbo smart boost controller, greddy BOV, b/s removed, moderate head work. completly rebuild motor. Holly 255lph fuel pump. Auto-Meter a/f ratio and boost guage.
Old 05-10-2006, 10:59 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
the cams should look like - - that with the makes lined up and the crank pully line should like up the the T on the timing cover, or you could put a screwdriver in #1 cylinder where the sparkplug goes and watch it for top dead center and look where the cam marks are then
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-11-2006, 08:33 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Originally Posted by dsm_dude12
im also pretty sure when i turned the motor by hand i heard a valve hit a piston.. im guessing its time to rebuild the head?? this is the first time with all this timming shit for me.. so correct me if im wrong on anything.
Not just the head, if it had been hitting the pistons you might as well consider buying a new set, you might as well just count on rebuilding the engine. When you get the head off make sure the dome of the pistons aren't damaged.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 05-12-2006, 12:07 AM
k. so i got the #1 piston to top dead centre. unfortunetly the cam pulleys timming marks looked off by a good 15 teeth. or how ever many degrees that is. so i guess im pullin the motor... good thing this dsm's in my hands or it just mighta been time for the junk yard. thanks for the help thoe guys!
Old 05-14-2006, 05:39 PM
ugh, i hate to bring this forum up again... but theres a thought in my head that maybe the valves are still good, and i really dont wanna take the motor out and apart then find out thats not the problem so anyways, the mechanic here told me to take out the plugs and turn the motor over to see if i could hear the pistons hiting the valves. so i did. and i dont hear a damb thing, the motor seems to crank freely. Could it be i got extremly lucky and all the valves are still good even thoe im pretty sure the timmings off a good 45 degrees and the belts still on turning the valves with the crank? this is really starting to bug me. also. if that is the problem. should it fire once i get the timming set up right without a balance shaft belt on or do i need the balance shaft belt on for it to run? i just dont get this and its starting to piss me off!! thanks once more
Old 05-15-2006, 09:44 AM
-Josh-'s Avatar
You could half ass it. Or you could play it safe and pull the head and see if there's any damage. You can spend money now, or spend more money later.
AF User Guidelines
Old 05-15-2006, 08:51 PM
k. so at the moment. i have a plan, but im not sure if htis is gonna work. im gona adjust the timming so its correct and try and fire it up to see if the valves are bent. any objection's to that? and also.. do i need to have a balance shaft belt on or the balance shafts removed for it to fire up just to see if it runs right? I am really ansy to see if the valves are good but the b/s removal kits gonna take 3-5 weeks to get shipped, so it would be mighty good if it would run right without the b/s belt or then romoved!!
Old 05-15-2006, 09:08 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
No the balance shaft will not stop it from firing or running for that matter. Why not do a comprssion test to see if valves are bent? Rather than say ok im gonna reset timing and turn it over to see what happens? If you insist in reseting timing im hoping you are turning it over by hand with a ratchet on the pully rather than the ignition.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 05-15-2006, 09:28 PM
ill try a compression test tommmorow hopefully if im not busy. i know this sounds really odd. but last time i checked the compression like 4 months ago it came up at 150, 150, 135, 80 and the car still pulled hard and beat several other talons, it didnt overheat and the oil stayed oil not milky mixtures of oil and anti freeze like a cracked head gasket would produce. it didnt blow oil out the exhaust either. so i unno but ill do the compression test hopefully tommorow and post the new results hopeing there the same as before.
Old 05-17-2006, 07:23 PM
k, so i ran a compression test today. it came up in all cyl's as 0. then i was freakin out wonderin how its completly 0 in all cyl's and my buddy said.. its cuse the timmings off, the valves are open at the wrong time. its making no pressure. im assuming he's right?
Old 05-17-2006, 08:02 PM
blk_srt's Avatar
if you timing is actually off then yes and unless its off exactly 180* you've bent valves
Mods:
Old 05-19-2006, 10:39 AM
thats the worst news ive heard all week.
Old 05-19-2006, 11:25 AM
blk_srt's Avatar
Well it can be a few degrees off but if its like 15* off then you have a problem. If I was you I would retime the motor and do another compression test to see where I'm at
Mods:
