Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-09-2006, 04:55 PM
GreyGoose006 GreyGoose006 is offline
Re: Gas Shocks
Si-212, How did you get the nut on the top of the front shock tight. the shaft keps spinning around inside itsself? i just tightened it as much as i could and used the supplied locking nut to lock it tight. i used vice grips to get the old one off, but they tore up the shaft real bad, and i didnt think that was a good thing to do to my new ones!!!
Old 05-09-2006, 05:11 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Gas Shocks
There's a flat spot in the shaft above the threads for holding it still with an open end wrench. You will also need an open end wrench for tightening the nut - which you can do through the wheel well with the tire off and the car secured.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-09-2006, 05:13 PM
Re: Gas Shocks
oh, i see it now. i dont have a wrench that small. i guess i could use an adjustable one. why dont they jus lock the shaft so it dosent rotate?
Old 05-09-2006, 08:37 PM
TommySS TommySS is offline
Re: Gas Shocks
Originally Posted by silicon212
The only problem with this is that a new shock is going to be fully extended, and that's a larger distance than the top mount to the bottom mount with the arms in the fully lowered position (as low as they'll go without removing the lower ball joint). The shock has to be compressed in order for the thing to even have a chance of getting the bottom bolts in. I generally take a shock from the box, remove the retention band, then compress it all the way in and hope I have the shaft lined up with the hole in the frame - because it's going in fast. Once one of the bottom bolts is in at least two threads, you can finish installing it. I always tighten the top nut as the last sequence of the procedure. I also disregard what a manual says pertaining to torque on the nut - I tighten it down until the bushing begins to distort - whether with rubber or urethane. In 25 years I've never had one come loose - but I have saved a few bushings.
As I recall, that's how I had to do mine (compress and move quickly to install)
Old 05-10-2006, 04:28 PM
Re: Gas Shocks
maybe im retarted or something but i bolted it on to the frame on the top, then used a jack to get it into position. seemed easier to me.
Re: Gas Shocks
maybe im retarted or something but i bolted it on to the frame on the top, then used a jack to get it into position. seemed easier to me. the
Re: Gas Shocks
maybe im retarted or something but i bolted it on to the frame on the top, then used a jack to get it into position. seemed easier to me. the rears were already compressed, so i cut the strap and timed it to get them on.
Old 05-10-2006, 04:29 PM
Re: Gas Shocks
i dont know what just happened there.
sorry
