Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-08-2007, 07:51 PM   #16
estirpe
Re: Easy way to figure out the bad ABS sensor
nobody with the answer??
estirpe is offline   Reply With Quote
Old 05-08-2007, 11:41 PM   #17
Cat Fuzz
Two hours is not long enough to wait for an answer.
Cat Fuzz is offline   Reply With Quote
Old 05-09-2007, 09:36 PM   #18
estirpe
Sorry, thanks a lot anyways I just sold it for 650 dollars...going back to hondas (less headache)
Old 05-26-2007, 11:57 AM   #19
Daddycat
Talking Re: Easy way to figure out the bad ABS sensor
Originally Posted by Will-n-SD
Just wanted to give an update to this.
I crawled under my Rodeo and looked for the connector 2eye said would be broken. Sure enough, I found 3 wires and a connector sitting there broken. I tried to take pics for everyone but my stupid camera would not work.
So here is what I did.
The connector is on the driver's side between the gas tank and the frame. First I removed the left rear tire for easier access. Then I disconnected the wire at the differential (there is a connector there too). I then removed every fastner there was so I could completely remove the wire that was from the differential to the broken connector. I then cut the old connector off and solder the wires. I then solder the other end that was still connected to the car. After both were good to go, I solder them together. Shrinked the tube I put on and reconnected it to the differential. Refasten everything and put the tire back on. Took it for a short drive like 3 houses down the street and the light went off. Now no more light.
Thanks 2eye and everyone else for the tips and help.
I have learned a lot from this site and plan to help in any way I can.
Ahhhhhh i love this forum! thx Will and 2eye. I found the same broken wires and hope my repair will be as successfull.
1998 Rodeo 3.2 manual trans
4X4 115,000 miles
bought used April 2005
Daddycat is offline   Reply With Quote
Old 06-10-2007, 12:51 AM   #20
bhuang1103
Someone out there can you help with an advise. I know by front left ABS sensor is bad. When I try to remove, I can't get the cylinder of the ABS sensor out. It appears if I remove the front rotor, I can easily hammer it out. Can someone advise if I need to repack the front bearing if I remove the front rotor. What is there other than removing the 6 bolts?
thanks in advance.
bhuang1103 is offline   Reply With Quote
Old 01-06-2008, 07:14 PM   #21
egc519mzl
Though an old thread but very informational. I will take a look at my friend's passport. I hope it has the same cause. Thanks...
02 Ford Focus @ 306K
97 G Voyager 3.3L V6 @ 122K. Trans leak fixed 5/2007
94 Jeep G Cherokee Laredo 5.2L V8 @ 159K re-fixed transfer case
last update : 01/23/2013
egc519mzl is offline   Reply With Quote
Old 01-07-2008, 09:32 PM   #22
andrew_j
andrew_j's Avatar
so what could be the issue causing the rABS and eBRAKE lights to come on and off simultaneously? It's been doing this since like 2001 one when the other owner had it he just didnt care to fix it lol.
1996 Honda Passport EX 4x4
On it's way to 161k FOR SALE!!!!
2000 Acuera Integra LS 5 speed
andrew_j is offline   Reply With Quote
