#16
Re: M22 Out!
a pic of where the bellhousing bolts to the trans would probably give storm enough of a visual to see if it would work. That is a freakin LONG drive shaft.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
#17
Re: M22 Out!
that's the pic i was lookin at, if you get can get that same angle w/ the tranny out i might be able to tell... the best situation would be w/ the bellhousing off... maybe you can just throw up a pic of it when you swing the motor out...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune. |
