Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 03-14-2006, 10:20 AM
neondawo neondawo is offline
Re: 2nd gen DOHC swap
Originally Posted by das2123
This is a good book that will help you and teach alot about modding your neon. I know one of the guys who helped write it and he is very knowledgable about neons...
http://www.amazon.com/gp/product/193...lance&n=283155
nice...i shall buy that!!
Old 03-15-2006, 04:25 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Anyone out there try putting a Magnum SOHC Head on a 2.4L engine? It seems like if you put in the 2.4 and attached the Magnum Sohc head, intake, exhaust and put in bigger injecters, you would have a good running combo, if you could find a timing belt of the proper size.
If you only used the non-magnum head and intake, I would think that there wouldn't be enough air flow to give it the same torque curve of the original 2.0 non-magnum engine. A Magnum head (w/cam) and the Magnum intake (with the runners set on secondary) may approximate the air flow of the original Sohc engine closely enough to make the computer think everything was OK. You would need 23 or 24lb injectors to make up the 20% more displacement of the 2.4L. Just a thought, I was hoping someone may have tried it before. If it ran OK, it would solve the 2.4l ECU problem. It would also look completely "stock" so the emission dudes wouldn't suspect a thing.
Old 03-16-2006, 07:59 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
I say do it and let us know!
