Old 03-13-2006, 07:27 AM
draybook draybook is offline
Re: My compression results
Excellent, thanks for the responses you guys. I'm pretty close to having enough to jsut go ahead and either throw in another stock motor or perhaps a ZC. My only question is this, is it possible and/or feasable to add a turbo onto a ZC motor on an automatic transmission? Thanks.
Old 03-13-2006, 03:53 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Hell yes it is, the turbo has no connection to the transmission....
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-13-2006, 03:59 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Those are some sad results. I did a compression test on one of my cars today and hit 160 across the board except on number 3, which wouldnt even read.... I think the guage yawned at one point. I'm thinking I have a hole in the piston.... woofuckinghoo.
Old 03-13-2006, 07:46 PM
So I can put in a ZC and turbo and it won't be a problem? If so then I might just keep this car for a while.
Old 03-13-2006, 08:23 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Are you sure you did the compression test properly?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-13-2006, 09:19 PM
Yeah, my brother in law did it and he had just tested his Prelude so there was nothing wrong with the procedure or the tester.
Old 03-13-2006, 11:26 PM
FrodoGT's Avatar
Yeah, alot of people turbo ZC's its a pretty good combo actually, I dunno about how great it would be with an auto trans though..regarding power/shift and things..but iot would work, if your going to swap the engine you may as well do an auto/manual swap as well, it wouldnt cost much, and if your mechanically, and slightly electrically inclined you could pull it off with ease...this is assuming the engine you get has a trans (the cost part).
Current project:
Rio Red 91 hatch.
Old 03-14-2006, 07:36 AM
I'm thinking about getting the ZC motor for now and next income tax refund next year I could do the auto to manual swap and throw in the turbo.
Old 03-14-2006, 08:17 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Auto plus turbo is a decent combo. But there is more to it with a Honda, especially a ZC... Aren't DOHC ZC motors relatively high compression? Wouldn't this require more tuning? Either way, you're going to have to run high octane fuel.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 03-14-2006, 01:27 PM
FrodoGT's Avatar
The ZC is not USDM, youd have to run high octane no matter what....Their standards are different and fuels have higher octane...
Current project:
Rio Red 91 hatch.
Old 03-14-2006, 06:56 PM
Here's a question. If I throw in a zc motor into my automatic, will I HAVE to use an auto pg7 ecu or can it be for a 5 speed?
Old 03-14-2006, 10:28 PM
duffman868 duffman868 is offline
it will need to be auto. you can runa auto in a 5speed but not the other way around
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 03-20-2006, 10:44 PM
J_Dog's Avatar
J_Dog J_Dog is offline
What should the average compression be on a 91 civic si? I got a reading of 75ish across the board. That was using a tester you screw in the sparkplug holes and crank the engine over.
Old 04-13-2006, 03:32 PM
cpolaris502's Avatar
cpolaris502 cpolaris502 is offline
Instead of starting a new thread i am bringing this one back.
I just tested my compression for the first time and i got 150psi in all cylinders. Is this good? By the way, my car has 241,700 miles on orig. engine and tranny. I used to burn a lot of oil until i put in some oil treatment.
It's a D16a6
