| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: Interference/Noninterference Engines
You look at the absolutely highest HP/cc engines being mass produced right now, sport bike motorcycle motors, there isn't a single one made in the last 20 years that was non-interference motor. There's a very obvious reason why. |
#17
not always, it depends on what the engineer is designing. if he's looking for low end torque, he's not going to design an engine with tonnes of airflow and no air velocity. and motorbikes rev up to 12000rpm, they need shitloads of airflow, that's why they need so much lift and compression, that's why they're interference. and saying that a non-interference engine can't get out of it's own way is completely wrong, they can and they do, they just might not rev as high or have the power of an interference engine of the same size.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them. Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood. On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear. |
#18
Like I said.... |
#19
if you read my post you quoted you'll see that i said interference engines don't always make mroe power than a non-inteference engine. if you can only run a certain ammount of compression because of fuel preignition limitations, and you increase flow to the maximum, you could still find youself with a non-interference engine. just because the valves can hit the pistons doesn't make them more powerful, it just means they probably allow more flow, which could be a bad thing.
another thing, you can have your pistons shaped so they don't hit your pistons, that doesn't decrease power very much and makes them non-interference. my point is that just becase and engine is concidered an interference engine doesn't make it more powerful than a non-interference engine. it's true that most high horsepower/cc engines are interference engines but they do that because they need the extra air flow. if you can't benefit from the extra flow there's no point in adding it, it might even remove power and torque.
#20
I read your post and understand it very well.
That doesn't change that your points completely miss my points, and seem to continue to miss my points. I never said that an interference motor MUST be high hp/cc, only that the variables involved in designing motors, makes it more likely. Imagine it like this, since you didn't like my generic answer: imagine a sliding scale of engine design. At the very tippy top of the scale, is the highest HP/cc engine in existance, which would be over 200HP/liter (we'll keep this limited, only NA (no power adders) engines, only on pump gas). These will absolutely most definitely be interference motors. Then as you go down the scale, around 100HP/liter, you will start getting to motors that are FEASIBLE to be non-interefence motors, and then as you go down from there, you will find more and more motors that are non-intereference motors. Do you agree with that? |
#21
... Its like two monkies fucking a football.... both have good intentions, and are horny as hell.... but in the end your fighting over a football in which to fuck.
Ladies... you're both pretty.
The point here that I think we're both trying to make is that designing a non-interference engine can be done with the same level of power, but the design characteristics make it intensely difficult to achieve that without killing octane tolerance, quench, flame front speed, rod length, etc. Anything can be done, its just that in general the bean counters have decided that $900 in service work every 60k miles is a good thing for the service department, so why worry about going to the extreme expense of designing one?
Dragging people kicking and screaming into the enlightenment. |
#23
I disagree.
Name me any motor, modified or otherwise, that is internal combustion 4 stroke (don't try to use the wankle motor...you know what I mean), runs on pump gas (93 octane at most, E85 doesn't count) that makes over 100HP/liter and is non-interference with no power adders. This isn't about bean counters, this is the simple relationship to port flow (which requires large valves, large lift, 4 valve realistically) and high compression ratio. You can't possibly have both and keep it non-intereference. Ain't gonna happen on pump gas with no power adders. Actually, even on race gas, it won't likely happen, to take advantage of race gas, you need high CR which unless you neuter the valve lift, you'll still be in the same boat. Last edited by UncleBob; 03-23-2006 at 01:13 AM. |
#24
#25
ah crap... server space is full.... pictures after I clean up my website
#26
#27
OK, a picture to help demonstrate:
![]() Its important to note that these are only generalizations. Not all interference engines look like the one on the right, nor do all non-interference engines look like the one on the left. But for the sake of discussion we'll be using these two for now. We'll assume several things for this lecture... I mean discussion ![]()
In general, in order to design a non-interference engine, the following happens:
Other generalizations are abundant. Typically straighter valve angles also means that larger valves can be used, but that's only a benefit if your engine's design requires larger valves. You can make a non-interference engine that makes the same kind of power that an interference engine does, however you have to engineer it in such a way that ALL of the problems become addressed in the bulleted list above. In truth they're not all that difficult to overcome, but that's where the bean counters come in. They look at the engine on the left that you spent two years developing to make the same power as the one on the right and they say; "but it will cost 20% more to make and we won't make as much money on preventative maintenance at our dealers' service departments." Its all a matter of what you're trying to design. If you're targeting drivers who know their stuff (like we do), do the non-interference engine. That way you'll have every grease monkey buying your car. That accounts for about 5% of the new car buying population. Not a smart demographic to play to. On the other hand, you have John Q Commuter who is buying a name like Toyota or Honda, who cares? You're not going to sell any more cars if you spend all the extra on the non-interference engine, and you won't get any residual money when JQ Commuter does $3000 worth of damage for not changing his timing belt when he should have. Shame on you, John. Regular maintenance is right in your owner's manual. You should have read it before you bought. No one blames the car, its a necessary evil of ownership just like changing the oil. Even if they ask, "when should I change the timing belt?" when they buy it new, they're not thinking about that $600 repair bill 5 years from now. They want the car. As a former bean-counter for several car companies, trust me. Its a bean counter thing more than you know. Everything is a bean counter thing in the car industry. Designing an engine for its long-term reliability is not a foreign aspect by any means. BMW, VW, MB, and several other companies often design their engines with 300k mile or more reliability, but many of them still use an interference design with a belt. Its just not a concern when you're selling new cars. One of the terms we use in the business is Temperate Elasticity. Basically its a parameter that shows the number of your new cars people are buying vs. how many used cars they're buying. Basically, if you have a die-hard Chevy fan, they are more likely to buy new than a 100k-mile used chevy. If you are a die hard BMW driver, a 100k Bimmer is a great way to get a much cheaper car that still has 150k of its life left. Its a double edged sword. Although its nice to know that the people view your car as a bulletproof tank, used car sales don't make money for the car company. So, tuning your company's Temperate Elasticity is always a battle between making cars that are reliable enough for your target demographic, but not so reliable that you lose too many sales to used autos of your own brand. Basically what that means is if Chevy suddenly came out with a vehicle that lasted for 500k and cost $60k, no one would buy it. Inversely, if Volvo came out with a Corvette-killer that had reliability issues and died at 100k, it would be corporate suicide. You build cars that fit your buyers, and almost never do you build high performance non-interference engines. The target buyers who would appreciate it only account for about 5% of drivers. Of that number, only a small percentage are new-car buyers, and of them a percentage would do their own repairs anyway. Not worth spending extra money that won't make you any money. SO, long story longer... on the topic of non-interference and Temperate Elasticity: Designing a non-interference engine wouldn't add any appreciable sales on the new side, but it would add appeal to the used side of the equation. It would skew your TE numbers toward the bad side. Instead they spend money on things like designing a timeless style or body shape that will help numbers on BOTH sides, new and used.
#28
In all of that you didnt explain why non interfiernce motors use rings that are crooked?
Nice, you should put that in the FAQ thingy.
Uh.... crooked rings help the uh, offset piston conversion from dis-centered head tolerance.... I'm retarded.
#30
First off, if you're talking about a 2 valve per cylinder design, you're already talking about low HP/cc without severe modifying that would require you to use race gas most likely. If you're talking about 4 valve per cylinder, which is needed to increase head flow, you have more valve area vs bore area. The more valve area, the less lift you can get away with and still achieve non-interference status. You need the valve lift to acheive good head flow also, which will greatly cut into your compression ratio. Seems rather simple to me. Greater performance REQUIRES reduced combustion chamber tolerances. It doesn't have to be a difficult answer. Yes or no will work. The answer is rather obvious if you ask me, but it seems many here want to make it a difficult one. |
