Old 02-23-2006, 01:03 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Box tuning?
You do want to have a certain amont of port area so that it doesn't make wind noises and so that there's atually the area there to properly handle the sound waves, but no as large as the tuning is correct don't worry about a short port.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-23-2006, 03:24 PM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
Re: Box tuning?
Who's a Dipshit bumpinstang77?
Old 02-23-2006, 04:43 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Box tuning?
All polyfill does in ported boxes is slow air flow clogging the port. Go ahead and do it and you'll feel kinda stupid when a nice hunk of it goes flying out of oyur port because its been clogging it up.
Old 02-23-2006, 06:27 PM
germanyt germanyt is offline
Re: Box tuning?
will there be a large difference in sound from 3 cubes per speaker and 3.5 cubes per speaker at 31 Hz?
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 02-23-2006, 06:28 PM
Re: Box tuning?
also, what if i wrap the polyfill loosely in some kind of fishnet to keep it away from the pole and the port? like a big loose block of it.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-23-2006, 07:33 PM
CBFryman's Avatar
Banned
Re: Box tuning?
if you where going to put polyfill in there i would reccomend you get the quilt lineing stuff instead and stple ot to the whalls, a few layres. the difference between 3 and 3.5 is 100% dependant on the speaker. you'll loose some flatness and possibly a decible or so but nothing too drastic.
Old 02-23-2006, 09:01 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Box tuning?
So the port acts kinda like a small fan ? I wonder where all the air comes from .........
Old 02-24-2006, 07:49 AM
Re: Box tuning?
CB Is the dipshit......... And yea Germany something like that to block it all off is good...... Everyone check this out.
http://forum.sounddomain.com/forum/u...=076651#000000
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-24-2006, 12:35 PM
CBFryman's Avatar
Banned
Re: Box tuning?
OMG!!!
Reat u on how hemholtz resonators work, why fiberfill is used in enclosures, and why ported enclsorues work Bumpin.
The driver presurizes the enclosure, the air goes to escape through the port, the driver causes a vacume, the air is pulled back in... IF some is to come loose and block the flow of air you are loosing SPL and chaging tuning by slowing down the pressur chages.
Wow, slowing down pressure changes, maybe that is why fiebrfill is used in Transmission line and 1/4 wavelength enclosures?
I like how everyone explains it as "tricking" the driver. Sure is cool to know my ava 18 has studied southpark and is all like "what ever, whatever, ill do what i want" Reguardless of what the amp is telling it to do and the only way to get it to do what you want is to feed it chicken skin (fiberfill).
Im not debating that you cna change how the driver acts with the enclosure, im saying it isnt a good idea. The ONLY time i ressomend putting anything in your enclosure is opencelled foam in enclosures large enough to have Nodes or antinodes. the link you posted stated itsself, 40% is the maximum you can gain...and that is by stuffing it to the hilt. what does that do? slow pressure changes and therefor tuning, even with the new "net" airspace.
Not only do you change tuning you will loose potential SPL. i doubt the difference between 3 and 3.5cuft with an SX is going to be drastic. a little bit more peaky, maybe an extra 1-2dB more peaky.
Old 02-24-2006, 12:50 PM
Re: Box tuning?
thanks for all the help. one more quick question, should i now refigure the port size for what the box will seem to be with poly in it? or is ok to leave it? i believe that leaving the same size will cause it to be tuned lower after adding poly to it so wouldnt that make up for the slight loss in low end due to the box still being just under 4 cubes per sub? i know 3.5 is nominal so should i concern myself with trying to make up for it at all?
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-24-2006, 02:42 PM
Re: Box tuning?
OMG!!!
Trust me I know more about this shit then you ever will.
LOL!!! Poly fill doesn't block AIR It slows down waves and moke the air seem bigger. Quit talking out your ass and look at the test. Always tryin to sound smart.
Once again you need to pull your b/fs dick out of your mouth and talk some sense.
Do you just like randomly make shit up as you go on. Like your own little fake Audio Physics????
Yea you tune it a little lower. You do loose a little SPL in the top end to gain some low end and a better all around sound. And the difference isn't drastic but its a decent change for the better.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-24-2006, 05:41 PM
Re: Box tuning?
so i should leave the port the way it is or reconfigure it for how the polyfill affects it? i still want to hit high numbers. if i dont hit at least 150 im gonna have a damn stroke. i could have just bought two si mag 12s and been able to build the absolute perfect enclosure instead. these SXs better impress me after all the stress im goin through with the install, not to mention all the time ive waited to do this.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-24-2006, 10:07 PM
CBFryman's Avatar
Banned
Re: Box tuning?
bumpin' im not going to sit here and aregue with you, im areguing with a wall. Germany, do what you want. I gave my advice so take it how you want.
Old 02-26-2006, 04:46 PM
Re: Box tuning?
i cant stand it when a thread turns to arguement. cb, i appreciate your advice and value it but i want to get several opinions. i know both you and bumpin are knowlegable and want ideas from both of you. i think im gonna poly the shit out of the box and tune to match it. if it doesn't change much of the volume of the box then it still shouldn't change tuning much. thanks for everyones help.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-26-2006, 05:45 PM
Re: Box tuning?
alright, ive been fucking around with winisd and i cant figure it out. there isn't a listing for the re sx. everything else is there but re. when i enter info for a new driver it tells me there is something wrong with qes, mms, etc. where can i get more on the ts parameters. the website asks for more info than reaudio.com lists. someone help me out please.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
