Old 02-14-2006, 10:53 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
Re: Headers
I was going to do the same thing, but I found out fast that a clamp right past the y didn't want to work very well. When my chasis flexed like, pulling into a driveway, the pipes would creak and pop like they were slipping, that's when I ditched the stock pipes for 3in. It's really not that expensive if you take it to a muffler shop and have them weld it for you, if you want to keep the stock stuff. If you have the money it would deffinatley be worth it to invest in 3in pipe from the y back, much better than the stock 2 and 1/4in or less diameter stock pipe.
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 02-14-2006, 10:54 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Headers
not sure why you took the valve cover off... go from underneath, its alot easier that way... coming from up top is pretty tricky
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Headers
i think mine is 2 and 1/2. and so will the shorties bolt up?
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-14-2006, 11:07 PM
97cavalier's Avatar
Re: Headers
and the ones i am looking at are ##500-68470
Old 02-14-2006, 11:08 PM
Nate355RS's Avatar
Re: Headers
I looked at doing it that way but it looked tough so I didn't even try, probably not a very good decision. And it is pretty tricky to get them in from the top, valve cover had to come off and knuckles had to be busted. Oh well, live and learn.
If you get the headers that match the stock pipe size I don't see a reason why they wouldn't bolt up, how well they will bolt up i don't know.
Old 02-14-2006, 11:10 PM
97cavalier's Avatar
Re: Headers
what i was worried abotu was the length, because i wanted them to bolt right on or clamp right on. no welding.
Old 02-14-2006, 11:12 PM
Nate355RS's Avatar
Re: Headers
I don't know if those will fit or not, says that they fit chevy aluminum heads only. It also says it has a 3in collector so I don't think they'll work as just a bolt on
Old 02-14-2006, 11:13 PM
97cavalier's Avatar
Re: Headers
damn, i see the ones you have, but i don't want to spend $300 on them. That is why i was looking at them.
