View Poll Results: Does your car idle like it should?
Yes. 21 47.73%
Fak no. 23 52.27%
Voters: 44. You may not vote on this poll
Old 02-26-2006, 01:38 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Re: Does your car idle like it should?
b16 = perfect idle.. however I need a bigger battery, idle slightly drops when i have my system pumped, and the headlights on.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 03-06-2006, 09:52 PM
4thgenSIR 4thgenSIR is offline
B16 - Nice steady around 700. Never had a stall or big dip. Very happy with it.
Old 03-07-2006, 07:41 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Question: You people with B16s and 700rpm idle... do you guys ride the clutch to get moving or are y'all constantly dumping it? Don't you have to get up passed 3k rpms to make power?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 03-07-2006, 03:06 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
...Yes, there is no moving below about 1500, and even then its very shaky...no torque..But I do Idle at 700 rpm.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-07-2006, 04:03 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Mine idles just fine. Dead nuts on 800rpms.
Old 03-07-2006, 04:57 PM
SiZ's Avatar
SiZ SiZ is offline
WTF?! Why would you need to "make power" just to drive the car? I seriously doubt it makes any less power below 3,000rpm than an A6.
Jebus, if you let the clutch out with the rpm anwhere near 3,000 you'd be flying off in smoke everywhere you went.
I don't usually even touch the gas to get the car going and my idle is around 900...
"The nympho of info, I'm fuckin' what ya heard"
Old 03-10-2006, 03:46 PM
hell no.. my lightened flywheel and stage 2 clutch gets me moving no problem
||JEFF| |
Old 03-10-2006, 06:25 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
the slight inconsistance in idle on the b16 is from the skunk2 intake mani....i just figured i'd take the chance to tell SiZ that my d16 idles better than the b16 :
w00t for 90civicrider's b16!
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 03-10-2006, 07:13 PM
SiZ's Avatar
SiZ SiZ is offline
Mine fluctuates before the car is up to temp. Once it is it will idle at 900, then switch to like 1200 for a bit, then down to 750. Fuck, it makes me nuts. I HAVE to fix it this year when I get the car back.
ALL the D series motors I've had idled well. But they were too slow.
Old 03-10-2006, 08:58 PM
FrodoGT's Avatar
Mine idles about 1000-1200 when cold, for about 2 minutes....they are supposed to do that arent they? Anyway, on the power thing...If I try to get moving without ANY gas, 1.)the car shudders like a cracked out monkey and 2.) It takes about 5 seconds to get moving, without dying....so at a redlight this is not suitable...
Current project:
Rio Red 91 hatch.
Old 03-11-2006, 12:30 PM
amy@af's Avatar
FrodoGT, i have 2 questions....
does it run lean?
does it run rich?
if it runs rich then check your hoses to the MAP. if they are okay check the MAP sensor it self.
next check IACV: take 2 screws off the back of the intake mani and you'll find a screen. take out, clean, and replace. follow that by the Fast Idle Control Valve...a plate on the back side of it, take it off and there is a nylon bolt that looks wierd (its slotted) screw it down (all the way in).
let me know how that all turns out boss
Old 03-11-2006, 12:36 PM
amy@af's Avatar
my d16y8 can take the b16 off teh line......
but then i have to shift as the b16 hauls past in 1st
i have a top secret project that should keep up with the b16...i gaurentee nobody is going to expect what i'm building next...providing my locals don't say anything
Old 03-11-2006, 03:01 PM
SiZ's Avatar
SiZ SiZ is offline
haha.. Booo D series.
I have a not-so-secret project comming that should be able to handle most D series motors.
Old 03-11-2006, 05:50 PM
amy@af's Avatar
who says i'm sticking with a d let alone a civic
Old 03-11-2006, 09:11 PM
SiZ's Avatar
SiZ SiZ is offline
Ohh.... Teh R??
