Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-07-2006, 01:40 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: turbo blown, time for an upgrade?
SBR turbos are $$. yes you will need a 2g kit.
Go over and look at English Raceing. It's our local DSM shop, awsome guy, exta fair deals. These are real deals too, not some bullshit over marked up price becasue they can. I beleve the MITSU Evo 3 16g is $529. Compare that to SBR $569
https://englishracing.net/catalog/in...Path=108_22_27
DSM geek
Old 02-07-2006, 02:34 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
Originally Posted by tsiskeetskeet
I've been shopping around and searching all morning and I think I'm going to go with the MHI EVO III 16G off of SBR. I already have intake, exhaust, boost controller, and boost gauge. I know I'm going to need the 2g install kit. I will probably need an upgraded fuel pump, but what about injectors? The stock ones on my talon are 450cc I believe. Is it really needed to upgrade the injectors also?
I don't want to spend over 1000 all together for this, so I was thinking if the MHI EVO III 16G and everything that comes with it exceeds 1000, then maybe I would go with the small 16g. It says on SBR that it's a direct bolt on. Does this mean I don't need the 2g kit or what?!
p.s. Thanks for all your input my fellow dsm'ers!
No 16g variant will bolt on directly to a 2g. That being said, get the EVO16g. The only things you really need are the SS oil line, gaskets and J-pipe. The T-25 waterlines, and oil return (with some modification) will be fine. It'll save a few bucks.
It sounds like you have a good start already as far as mods go. You don't need an upgraded fuel pump right away but you will want to get it soon. It's best to be safe and rewire your stock pump until you get a 190 or 255. The stock injectors will be fine for now. I'd say, if you do the rewire, you'll be able to safely push 14 psi. I'm at about 12 and it's a little bit more juicy than stock. 14 should be noticable.
You can do it in bits but don't get excited right away and crank the boost. No reason you'd have to drop more than $1000 in one sitting.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 02-07-2006, 02:39 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
http://www.extremepsi.com/store/cust...cat=426&page=1 evo 3 for $529 shipped.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 02-08-2006, 03:42 PM
tsiskeetskeet tsiskeetskeet is offline
OK, so I decided to spend some $$...I bought the mhi evo 3 16g from SBR with the inlet and outlet turbine ported and also a walbro 255 fuel pump...it should come in saturday and I'll try to get it put in the following week...I'll let yall know how it is...thanks for all you're input!
Old 02-08-2006, 03:55 PM
Sweet pick-up. Make sure you get an adjustable fuel pressure regulator if you are going with the 255. You'll run the car really rich and have problems if you don't.
I went with the 190 because it will flow just under what the EVO16g requires at it's maximum output when rewired. I figure I will probably never do everything required to max out a EVO16g (cams, excellent tuning, etc..) so the pump will cover all of my needs and I can save some $$ not buying the AFPR. I've also read a discussion about a rewired 190 with larger fuel lines being able to fully support an EVO16g. Don't remember where I read it though...
I don't want you to second guess your purchase but I want to make sure you know that you need to get the APFR too.
Old 02-09-2006, 12:49 AM
Yeah, I can always call up SBR 2maro and change it cuz they wont send it out til 2maro afternoon...if you happen to remember where that discussion was, post it please, it would be greatly appreciated, but I'll probally be up all night looking for it...
Old 02-09-2006, 01:50 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Definitely need the FPR. Some people will tell you there car was running fine without it, but the car was definitely having problems.
now - 2000 civic
soon - 2002 is300
Old 02-09-2006, 07:13 AM
It was on DSMTuners. When I get to work today, I'll try doing some searches. I remember being torn between 190 and 255 but that discussion made me 100% confident in the 190.
*Edit: Not the link I was looking for, but should help with the piece of mind going with a 190.
http://www.dsmtuners.com/forums/show...190+fuel+lines
