#16
Re: 1991 Accord DX tranny problems
yes i do know what you mean i have used the practice every now and then?
what manual are you refering to and where can i get it? |
#17
go to parts store and get a haynes repair manual or chilton..
autozone , kragen , partsamerica, shucks, pepboys, napa, checker, walmart, etc...... |
#18
can you post a picture of the speed censor and where it is lockated at?
#19
Check the FAQ, there is a HUGE section devoted to the speed sensor replacement. Also a section to pull your own codes. Autozone probably wont be able to do it, because as far as I know they only have an OBDII scanner, so only 96+.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
#20
yeah is it not a little cheap loking key that fits into two slots in the reader..
they give them away for free.. |
#21
is it hard to replace a tranny on these cars? the reason i ask is because i found a pick and pull that sells the tranny for about $25.00 and has a 31 day return policy. i was wondering if it is worth the risk or not. i took the car in this morning and the mechanic said he recomends the rebuild. he is going to keep the car over night to test drive and pull the codes then give me the results. he said he would try to keep the cost down but he thinks it will be somewhere between 1300.00 and 1500.00. what do yall recomend?
#22
Read the FAQ. replace the speed sensor. That will cost $50 and probably fix your problem. If not, then you can start worrying about rebuilds. Of course the mechanic will say it needs a rebuild. He makes more money that way...
#23
do you think the speed censor will fix the problem with the shifting of the tranny?
#24
look at it this way ..
if he does a rebuild than he will replace the sensor ... if you get a tranny you will need a sensor.. just go get the sensor and fix that problem and tell us what else is on the trouble codes.. tranny swap will take a while to complete... if your good at what you do look in the 4-6 hour ball park... i agree its to early to call just to let your mechanic have it .. |
