#16
Re: Did the "professional" injection cleaning
Steve, Still working through it. I put on new coils....no change. I AM however no longer getting one cylinder misfiring....it is random misfire code now (P300)....I bought an entire set of injectors off a blown up 3800....w/ 48 k on them. Think I am going to install them and see where that gets me...worst case...these have a lot less miles than mine...and I got them all for 30 bucks!!! |
#17
Oh....and I did think about the possiblity of the wiring too...how the hell would I check that though?
#18
If you're talking about the injector wiring, you can buy a cheap "noid light" set. unplug the injector, plug the noid light and crank the engine. The noid light will flash if the harness is ok. Check each injector individually.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
#19
Cool......was thinking about a test light...but sounds like there is a better way
#20
Thanks Blue.....will it work to put car on jack stands put the car in drive and reverse to isolate it...or will there not be enough resistance on wheel at that point?
#22
Well.....I got a p1404 code today.....EGR Closed Position
I cleaned the EGR vlave a couple weeks ago......could the misfire problem be triggering this code some how? Also.....I notice that the clunking in the fron end DOES NOT happen when it is really cold outside.....but...when it is warm, it is worse. |
#23
#24
Hummmm. Got that code off of the 9145 Actron. You think it is not reading properly and that is is actually sticking open?
#25
"Detects if the EGR valve is stuck open when commanded closed, otherwise DTC P1404 will set".
#26
98 GT w/ 3800
Wow Bob...this may the answer then. Maybe to misfires too? |
#27
The other thing the EGR valve does when stuck full or partially open is cause a lean trim condition to the fuel injection system resulting in misfires and a host of other problems. Good luck! and cross your fingers.
#28
Hummm. Interesting. I cleaned that bad boy up too....and to no avail I suppose. And by the way...the code was "pending". Another thing to note is the smell of my exhaust at idle. It smells rich.
What do I do? Should I try and find a used one? My wife is ready to kill me with all the money I am spending on chasing the problem. She now contends that I should have taken it to a mechanic...and told her..."he would have to chase to"...and for 75 an hour!! |
#29
#30
EGR VALVE Part #: 17113284 CORE CHARGE: $0.00 GM LIST: $195.75 OUR PRICE: $97.88 GM PARTSDIRECT.COM Check with Richtazz. He's the parts specialist. Part # for 02 is : 12568582
