Old 01-18-2006, 04:22 AM
cenzixao cenzixao is offline
Re: Uh oh, big problem here !
Originally Posted by malletslinger
When you checked the fluid level in the trans, the car was running right?
Did you take a look at the coolant to make shure it looks like a 50/50 mix?
I know its hard, but try to relax, take a brake. I own an 89 with the 2.8 and I have had a lot of problems too, but I have also learned alot about cars more about cars and Ive had a lot of fun. I am in college and have been trying to deal with a big problem myself for over a month now(see blowing gauges fuse...please help). I have owned my camaro for over 4 years and have considered selling many times(beleave me). I could own a newer car with better MPG and fewer problems, but I like the way my camaro looks, handles, sounds, and drives. Try to remember that any and all used cars have problems, but you have to like what you drive, otherwise, why would it be worth fixing?
When you are rested, think about all the symptoms of the problem and be as dicriptive as possible when you post them... for example, "making like this vrroom vroom vroom sound"...do you mean the engine keeps reving or ideling roughly? and when does it happen? When you are slowing down, stopped, ideling, changing gears(which gears)...???
What collor is your tranny fluid? Does the problem happen when the car is cool (havent driven long...first ten mins or so) or when the car is warm?
Do you have the AC or Defroster on when problem occurs?
These are things we need to know to try and help you.
Well the vroom sound when Im accelerating, its basically sounding like the engine is trying really hard but just has no power. The rpm get up to around 3-4 and Im up to past 40 before the car finally changes gears. when im at a full stop and accelerate the car feels very weak getting back up to speed. The engine idles at like .5 rpm. The trans fluid was dark and really low when i checked it, but then i put fluid in and its still acting up. It does the same thing whether the car has been running awhile or if i have my heat on or whatever. The car runs really rough and shakes. when I go out to try to start the car after its been off for a few hours It takes a few tries before it kicks over, and some of the time when I turn the key i hear this drilling sound. If i try to start the car up within like an hour of it running for a little while it starts right up.
within the past few weeks the car has received new starter, battery, spark plugs, air filter, water pump, radiator, thermostat, my fluids are full. i just dont know..
Old 01-18-2006, 05:58 PM
malletslinger's Avatar
malletslinger malletslinger is offline
I am fairly certain that the tranny is not the problem(mabe the govenor, but I doubt it) because most of these problems cant be related to the trans, so you can check that off the list.
*Next you should replace the fuel filter and PCV valve, and check for vacuum leaks...The problem might not be the fuel filter or PCV valve, but either of them could be contributers to the problem and are inexpensive to replace...if they arent the problem, atleast you will be able to check tham off the list.
*Next item to check is the MAF sensor(mass airflow sensor). They are too expensive to replace if they are not the problem, find someone in your area who will let you use their MAF sensor for a few mins...take yours out, plug theirs in, and drive for a few mins. If that isnt the problem, put your MAF back-in, check that off the list, and be happy that you didnt waist a minimum of $200.
Let me know if those things didnt fix the problem, because I have other ideas, just dont want to confuse you with too much at once.
BTW: Has your car been overheating?
Old 01-19-2006, 12:36 PM
It was, until I just had the radiator, thermo, and water pump replaced.
Also today I was driving and while in a trafficy parking lot the car was realy loud when it was dropping into gear
Old 01-19-2006, 01:41 PM
Do you mean it got loud after it down shifted, or the engine got louder(reved up) while shifting? or do you mean you heard a loud 'clank' noise?
Have you started checking those recomendations I made yet? Have you checked your tranny fluid level since you added fluid? Does your car have any leaks?
Is your engine cooling fan electric, or does it have a clutch? (Just making shure.)
Does white or black smoke come out of your tailpipe?
Old 03-01-2006, 01:09 PM
TheSavant TheSavant is offline
Originally Posted by cenzixao
all of a sudden the car is running REALLY sluggish. Its like when i push the petal the car has barely any acceleration, my RPM goes way up to like 4, and the car gets kind of loud. Could this be my belt?
I am having the same problem. Only I have a '96 Cam. with 5 speed manual transmission. It has a hydraulic clutch. I could still drive it, until today. Now there is almost no power whatsoever and a high-pitched whining sound. Good times.
Old 03-01-2006, 11:44 PM
You really shouldnt post on old threads like this when they havent been used for a while...it has been a month and a half since the last posting and unless the person who started this thread posts an update or an other question about this problem, then it should be considered a dead thread... If you are having a problem, you should start a new thread...
Also, Welcome to the forum Savant
Old 03-02-2006, 01:26 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
check yer damn fuel pumps
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 03-02-2006, 03:13 AM
Ah, just didn't want to clutter things up. Thanks for the tip and the welcome!
