#16
Re: Re: Re: 1998 Blazer fuel pump stopped
On these assemblies ('97 to '05) there's three lines, a feed (5/16"), a return (3/8"), and a vent. They are all plastic lines, and the feed and return lines have pinch connectors on them. The vent line is just a push-on pull-off flexible fitting. If you ever take these lines off the pump assembly, get new pinch connectors (I didn't, and had to drop the tank again to replace the leaking connectors- and I broke the plastic outlet on the pump assembly to boot- very expensive ).
It's my opinion, don't take it personal. '04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC |
#17
No,No I solder the lines while the whole assembly was on the bench.I was also refering to the 95's
#18
I had a similar situation and I couldn't figure out which pump I had before the parts place closed, so bought both(700 bucks later) and planned to return the other. I opened the boxes before I dropped the tank and one had a service bulletin in it that said the the '98 blazers (maybe others) had faulty electrical connectors on the end of the vehicle wiring harness. There is a$5.00 kit made that replaces this connector. If you notice that the plug on the top of the pump is worn, melted or full of dirt, you've solved the problem. I solved mine my wiggling the plug, and it worked! Then I opened up the plug, cleaned the terminals and put dielectric gel into the plug and TA-DA, the pump has run perfect since, without dropping the tank, without buying the kit, or replacing the pump and it only took about 10 minutes to fix. I would try this before even dropping the tank!!!
Apparently there is a TSB out on this and the shop people I've talked to at my local dealer they think it should have been recalled, but they're not making this cheap fix known to the public... Figures. |
#19
Something that I have not come accross in this thread yet is the fact that if the pump is loud enough while running, it is a good sign that the pump is going out...it may be tomarrow or a couple of years before it finaly goes but its well on its way...if your driving down the road and its been driving you nuts and your s10 dies, and you turn the key and dont hear it.....ill bet money that the pump is shot. This happened to me 2 weeks ago and now I love it.....no humm.....plus I did notice performance increase after I installed the new pump...also make sure that seal sits down into the tank....I have to drop my tank again and fix this.....it leaks when I fill her up...
#20
Not to be picky but a humming form the fuel pump isn't 100% bad. When you turn the key on or off you should hear the pump prime with that wonderful sound. Not hearing it is a sign of being totally dead. I'll agree hearing it loudly while running isn't good but the pump on mine has whined since the factory, it made it about 90,000 (died w/o ANY warning) and the new one made a slight sound too(currently has 45,000mi on it).
#21
#23
Yesterday was a really nice day so we tackled the fuel pump.
Removed the fuel pump from the tank and bench tested - dead. Bought the new fuel pump, $270, and bench tested it before getting it "wet" - worked. Reinstalled everything and going good. The job took about 4 hours. If anyone has any questions on problems we ran into etc, just let me know. Thanks for all the good advice. |
#25
While I was at a dealer the other day I saw that they Guarantee the factory pumps for life... I didn't push the issue but maybe an option for replacement...?.. I also have a part number for the wiring harness on the fuel pump. I have an 18 gallon tank in a 4.3L 4Dr 4X4 but the Napa # is 888-543. The variations are: 888-544, or 888-553 depending upon your pump. It comes with new plug, about a 4inch wire lead, crimps and heat shrink. Not bad for 13.00 instead of the 351.00 pump. |
