Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-14-2006, 12:59 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: please help with timing belt
It's right on the crank where the crank sprocket attaches. If you still don't know what i mean i'll go take a pic of my brother's we still have his engine apart
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-14-2006, 10:28 AM
SLoe's Avatar
SLoe SLoe is offline
Re: Re: please help with timing belt
Originally Posted by ez1286
No, crankwalk wouldn't cause anything like that.
Yes, it would.
mitsutuner have you had any trouble disengaging your clutch,especially when you turn? You need to get some sort of prybar and a helper. Take the bar and try to move the crank toward the passenger side. Then remove the bar and have your helper push the clutch pedal while you watch. If the crank moves toward the driver's side you have problems. If not you are probably OK on bearing failure. You can try to measure the movement with a feeler gauge too.
If your key was gone, and your pulley slipped you would be out of time. Out of time on an interference engine = bent valves, and I doubt your car would run like that. What do you think?
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 01-14-2006, 10:54 PM
mitsutuner13 mitsutuner13 is offline
Send a message via Yahoo to mitsutuner13
my car is an automatic...so how do i check it if its an auto.....not having a clutch to push in and stuff?....thanks so much for everybodys help so far....i know this is crazy....but i need all the help i can get.
Old 01-15-2006, 01:35 AM
ez1286's Avatar
Originally Posted by loeman
Yes, it would.
Yeah i don't think the car would run without the key, it might though if the bolt was tight enough...I don't think you'd get the tbelt frayed like that with crankwalk, cause its only out of alignment by .009" with cw which i don't think is enough to do that sort of damage to the tbelt.
Maybe some pictures could help with this...
Old 01-15-2006, 09:05 AM
SLoe's Avatar
double post
Old 01-15-2006, 09:11 AM
SLoe's Avatar
O.K. First, you need to put your car information in your signature. You can still measure end play, but since it is an automatic we wont worry as much about that. You seriously need to take some pictures.
Ez, where did you come up with that number? .009 is not even close to how much the crank will move when the bearing fails. When I noticed my car had CW, the pulley had moved so far that it and the belt had rubbed completely through the timing belt cover. So yes it will move far enough to fray a belt.
i will post pictures today and put some info on my profile......srry bout that guys.....i will have the pics up asap.....thanks for all the replys and keep them coming
Old 01-15-2006, 09:12 AM
Old 01-15-2006, 05:05 PM
ez1286's Avatar
.009 is out of spec. There is no way the is enough room for the crank to move to cause the belt to fray. I'm thinking it's another problem. oh i got the number from vfaq.
Old 01-15-2006, 06:05 PM
SLoe's Avatar
Crankshaft endplay tolerance is .0020 to .0071 inch. So .009 is out of spec, but not the limit of how far it can move before it hits the sensor. Think about how thick the thrust bearing is, it can move a lot. I am speaking from experience. I have the timing cover to prove it. Bearing failure is not as likely in an auto, but it can happen in any car. Don't rule it out before you check it. It is not hard to check at all. You may even be able to move the crank with your hands. See how much that bearing is worn? That is paper thin and way more than .009.
Old 01-15-2006, 06:35 PM
i checked and there is no endplay.....so im relieved about that....sorry i havent got the pics up yet...its been a rough week with me since i dont have a car.....i will get them up asap. by the way....my belt isnt rubbing on the side where the timing cover is, its on the side closest to the block. the belt is riding on the tensioner pulley's lip on the inside of the pulley. the crank pulley seems to be too close to the block....but this may not be the problem after all because ive checked everything that you all have told me to. is there anything besides the crank pulley that would make the belt ride too close to the block?
Old 01-15-2006, 09:40 PM
ez1286's Avatar
Are you sure the tensioner is tight enough? If it could move back and forth that would cause some problems. Did you replace the tensioner when you did the timing belt?
loeman I'm not trying to start a fight i've just never heard of that and i don't think there is enough clearence to have the belt hit the cover, there is signifigant room between the belt and the cover,(in terms of engine clearance) and if it were that far out the counter weights on the crank would hit the main cap.
Old 01-15-2006, 10:44 PM
SLoe's Avatar
I am not going to fight, just stop calling me a liar. I was talking about the belts outside the cover moving far enough to cut into it, so maybe it could also move far enough inside to fray the T-belt. I am done with that subject. So let's get back to helping this guy. Peace
Anyway, I am glad that isn't the problem. mitsutuner, you keep mentioning the pulley looks too close to the block. Use a string line, and check the alignment and you will know for sure. The only other thing I can think of is something is not tightened, or something is bent. Belts will always ride to the "loose" side of a pulley, away from tension.
Old 03-03-2006, 11:34 PM
i checked the alignment of the pulleys and the crank pulley IS closer than the other ones
mitsutuner13: 96 mustang GT ....i have steeda lowering springs, k&n cone filter w/ adapter, Mac X-pipe with dual chamber flow masters.
