Old 01-14-2006, 12:26 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Sounds to me like maybe compression. same shit used to happen to me in my S-10 pick-up
http://jowulf.deviantart.com/
Old 01-14-2006, 01:41 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Quitting
Originally Posted by rlith
huh?
My thoughts exactly, I think he isn't listening to us.
Also Ricky, stop bumping the topic to the top.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-15-2006, 04:46 PM
Ricky Reynolds Ricky Reynolds is offline
Re: Quitting
Checked all vent lines, change the IAC, checked the compression, checked the timing, cleaned the trottlebody, checked the battery voltage, checked the charging system, changed the coil, checked all the wires, and still got the same results.
Old 01-15-2006, 05:04 PM
BlazerLT's Avatar
AF -Advisor
Re: Quitting
Oh just forgot, how about the ignition module on the distributor.
Old 01-15-2006, 07:05 PM
Re: Quitting
I replaced the distributor with a new one, had module and new picpup coil in it. Also replaced the cap and rotor button.
Old 01-16-2006, 01:06 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Quitting
For some reason the cheap wires don't last long in Blazers. So if you used a cheap set they might still be your problem.
I don't like suporting the dealers often but OEM wires last the longest
Old 01-16-2006, 08:24 AM
Re: Quitting
The plug wires were the most expension ones they had.
Old 01-17-2006, 10:54 AM
Re: Quitting
Well! I'M Stumped on this one. Tried everything that has been mentioned and it still quits.
Old 01-17-2006, 12:27 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Quitting
Yes, yes, that's nice - but are they AC/Delco wires?
Most expensive doesn't mean they are good for more than sparking over your push mower. Stick to AC/Delco on the ignition parts. Return the wires you got, and take your cash to the parts counter at a GMC/GM truck delaership. You'll be surprised how inexpensive the *RIGHT* stuff is.
Old 01-17-2006, 02:42 PM
BlazerLT's Avatar
AF -Advisor
Re: Quitting
Check all grounds and check to see if the fuel pump is priming.
Old 01-17-2006, 08:41 PM
Re: Quitting
That was the first thing that I did check was the grounds and fuel pump.
What I can't understand it WAS NOT quitting until after I replaced the distributor, cap, and rotor button.
Old 01-17-2006, 10:31 PM
BlazerLT's Avatar
AF -Advisor
Re: Quitting
Well that should be a starting point, check for continuity on the coil wire.
Old 01-18-2006, 12:30 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Quitting
My 1991 Blaser will just quit when you are sitting at a redlight or stop sign. It quits in drive or reverse. Anyone have any suggestion?
Alright, I have a question, does you truck run and then just quit, just stop right away, like your stopped at a light, you waiting and idleing, and all of a sudden it shuts off, OR does it run, but once you put it in gear, the idle gets so low, that it just dies out. These represent two different scenarios.
Old 01-18-2006, 07:52 AM
Re: Quitting
It idles normal and then all of a sudden its like you just turned the switch off. It does it in drive, while sitting at a stop light, and sometimes when you put it into reverse.
Old 01-20-2006, 03:40 PM
Re: Quitting
I checked all the wires and everything is fine with them.
