| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: Octaine equivlent of Nitro Methane
Sorry to burst your bubble kid, but your not going to think of anything that hasnt been done before just by using a differnt fuel or changing a minor detail.
Re: Re: Octaine equivlent of Nitro Methane
By mixing a low octaine and a high octaine fuel you do raise your avrage octain rating of the low grade fuel which raises your pre-ignition temps, which is exactly what I want. The mixing of two liquids that do not react with each other on the molecular leval will result in a mixture that has the properties of both in proportion to the percentage of which they were mixed, me and my chemestery teacher had it out as to any exceptions to this rule, it applies to all liquids, and vapors too I think. |
#18
BTW how is your worlds largest vibrator coming LOL
#20
Your problems are going to lie in getting your a/f ration right and big problems with internal engine corrosion.
By the way, the vibrator thread was an inside joke- that you obviously did not understand.
Do I have to close another thread?
Don't make me stop this car! Let's keep to the topic. Flames are for PMs. ![]() Kachok25, your question is valid, but SilentChamber and the others are correct, too. Its probably been done, but the hundreds of pitfalls associated with it make it unfeasible. So, back to the original engineering aspect of it, let's find the actual octane rating of Nitro and then do some math. No problem bench racing it and using new information to expand your knowledge, but let's stay realistic. Its not going to really work on the street. I have seen staged injectors firing Methanol for high boost situations. A guy kept his 10.2:1 in his NSX and used two VATN aerochargers for about 10 psi. In order to keep it in one piece he piggybacked a simple injector computer and six nozzles to start laying on the alcohol when boost hit 4 psi or so.
Dragging people kicking and screaming into the enlightenment. |
#23
That is really cool, all I needed was a piggyback ECU, six injectors,a small tank , and a fuelpump. That would be one of the best mods doller for doller around if you figure that alcohol can handle about 15psi more boost than 92 oct gas. Or about 7psi more with an even amount of both at full boost, that would allow about up to one bar on a high CR engine! How much would an intall like that run? I imagine it would require some fine tuning at the dyno though. Was there any other special mods that he had to do to optimaze the alcohol injection setup?
#24
His install was over $10k if I remember correctly. It requires a completely separate dedicated fuel system, including tank, lines, sensors, computer, injectors, welding modifications to the intake, etc. All of the issues of EFI times two.
Other than that its basically figuring out the math and making a base map for the alky.
#25
I think I could do that install for way cheeper than that I have seen complete fuel injector conversions including manifold for 2k. But I guess that is assuming that I do all my custom fabracation and fine tuing by meself. I wounder if anybody sells aftermarket kits for just this purpose.
#26
Actualy now that I think about it I could probably attach a high flow nosle onto a water injection system ($500), it is boost actuated, now I just need to find a way to make it flow enough (some of them run 150psi), I seem to forget my forumula how much alcohol per minute would I need to sustain 100hp?
Update: Cooling mist makes a twin nosle kit with 150psi of pressure, their nosels are rated for up to 18gph so assuming that the pump can keep up with twins I could flow 36gph how much HP could I support with that? I am not sure one pump can keep up but I could intsall a second pump I just don't know if I can make it run off the same computer. It would cost me around $400 with twin pumps. Is there somthing that I am missing here or is this a relativly safe idea? |
#27
You could guess, but you'll be incredibly rich under low boost and incredibly lean under tall boost. You can't just inject massive quantities or wait for a pump to build pressure. That half a second could melt pistons.
You need the whole thing; computer, fuel map, boost-referenced pressure regulator, MAP sensor, the works. It has to be spot on for all conditions, not just a flood that hits the middle.
#28
If I did go with the whole fuel injection system could I use the regular sensors and use an ECU with water/alke injection already calabrated into it? I know they make them. Oh BTW I would not be using this system much just for the occasinal trip to the track so running a little rich would not be a prob. And do you know how much alcohol I would need to run to make an extra 100hp? Would 18lbs an hour be a good enough flow rate. If not the pump is rated for 1.5 GPM I would think that would easly be enough for almost any applacation. Last edited by kachok25; 12-24-2005 at 08:45 PM. |
#29
Duh my bad they go up to 18gal per hou not 18lbs per hour. Two of those would accamadate just about any injection needs I have
They claim it is instant, and that the computer is programable with 10 fixed algorithms which is as accurate as I would need on a 1/4 mile run I think. Would there be any downsides to using this as opposed to a custom piggyback controled EFI system? Oh and one more thing would the EFI have to be built for methonol? I know parts built for gas don't like it much.
#30
methanol eats away at rubber so you'd have to raplace anything with rubber.
