#16
Re: ABS INOP.. is this normal?????
you guys do realise that the light turned off after i restarted the car, and has never came back on, right?
#17
Your brake ECM much like a engine ECM (or PCM used in more modern cars) uses a memory to retain the reason why the light was on. If you pull the brake codes. It will tell you what the problem was but no I was not sure if it was still on or went off but since it was on. I am sure you have a code in there.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
#18
The ABS sensor in the hub may not be working correctly if the light should stay on. This is like an $18 part at O'Reilly's. It shouldn't affect your driving, but if you get on a slick road, and try to stop that wheel may not work as it should. Ooops.
#19
Wow.. almost two months
![]() car audio guru...
