Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-06-2005, 11:02 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Problem Under Hood Please Help
actually if it was a slipping belt it would get louder with the load on the engine /rpm. A belt squeal is an obvious sound, this is definitely a vaccum leak. While the car is running, pinch off different vacuum lines. They should all cause the car to idle weird, once you find the hose that doesn't cause the idle to fluctuate, find the hole in that hose.
now - 2000 civic
soon - 2002 is300
