Old 11-30-2005, 06:27 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: P0141 and P0443 Error codes?
Please guys no stealing, it's illegal.
Old 11-30-2005, 06:28 PM
MexRocket's Avatar
MexRocket MexRocket is offline
...... what?@!
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 11-30-2005, 06:35 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I'm pretty sure the fuel pressure solenoid is not necessary
"...The right-most solenoid, marked with a green arrow, is the fuel pressure solenoid. This solenoid allows the engine control computer to temporarily raise the fuel pressure for hot starting purposes. This is accomplished by cutting off the vacuum hose going to the fuel pressure regulator. It is not used for anything else..."
This is from http://members.shaw.ca/dsm.1000q/Eng.../solenoids.htm
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 11-30-2005, 11:35 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Ooh, Ha, i though you meant you completely removed the regulator...duh, nevermind....
Old 11-30-2005, 11:40 PM
ez1286's Avatar
oh lol yeah that might cause some problems, As of right know i think i solved the problem i set the base idle and i drove it around turned it off drove again, seems to be ok, keeping my finger crossed for tomorrow...
Old 11-30-2005, 11:41 PM
ez1286's Avatar
My bad i meant base timing
Old 05-06-2009, 02:50 AM
ssmng ssmng is offline
P0443 Error codes - Toyota?
Dear All, need some help here.
I am driving a 2004 Toyota Vios 1.5L 1NZFE which recenetly have the "Check engine" light ON. A local auto shop check error code and found P0443 (Evaporative Emission Control System Purge Control Valve Circuit Malfunction). They change the Vaccume Sw (17650G) but the problem after 10 mins, the Check Engine Lights is still ON with the same code.
They have no solution for me..!
What else can I check?
