Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 12-07-2005, 10:28 AM
noma96 noma96 is offline
Re: Re: removing factory radio help
Originally Posted by rlith
Tried to tell ya, drop the knee bolster and lay the steering wheel in the seat...How the hell did you get the bracket nuts off the steering column without removing that!?
i removed it and took the nuts off but still cant get the column off the bolt the bracket is right above the brake pedal right?. ill get you a pic im layed off from work so i have all the time in the world.
Old 12-07-2005, 10:39 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Re: removing factory radio help
You've been working at the base of the column all this time?!!?!?! The bracket for the column is at the TOP of the steering column, just under the knee bolster! No wonder you're having problems! You're working at the bottom, not the top of the column. Nothing needs to be removed at the base. Just the 2 15mm bolts at the top
Old 01-06-2006, 12:28 PM
miller88 miller88 is offline
Send a message via AIM to miller88
i have a GMc sonoma and i had problems geting it to what u do ispull it as close to the streeting wheel u mite have to bend it. the force the drive side part of it out then swing it around.
