Old 11-13-2005, 07:22 PM
Skugulgurk's Avatar
Skugulgurk Skugulgurk is offline
Re: Re: TB Spacers / Twisters
Originally Posted by Thor06
The bumps are there to make the air churn around more so the fuel gets more evenly mixed, not so that it gets colder. I am willing to bet those shallow ass grooves arent deep enough and the spacer isnt long enough to get the air to spin, they will act just like big versions of those bumps in the intake manifold. So yes, it may help (very little if any) to have that spacer but it wont be because of spinning the air, it will be because the air was given more bumps to go around to give it more turbulence to better atomize the fuel.
Yep Yep, as far as I know turbulent air is a benefit because it helps the air fuel mixture be more complete. Or as thor06 said it lets the fuel atomize better.
Bernoulli’s principal says that if the speed of a moving fluid increases the pressure of that fluid will decrease. (Air is a fluid)
And we've all seen space movies so we all know that air travels from an area of high pressure to an area of low pressure. Just like someone getting sucked into space when their spaceship cracks.
If this device does do as it claims and spins the air and it is a little smaller than the rest of the intake tubing then that would mean there would be in increase in air speed which would make an area of lower pressure at the spacer. That would force a TINY bit more air into the throttle body. but, I doubt it would be enough to make a difference.
I hope I've at least helped out a little bit now. Most of this is memory from ground school so It may not be worded exactly right, but I'm pretty sure the ideas are correct.
And david-b, It may have been that you found intakes that increase air speed without to much compression. If that were the case then we know now that if air moves faster it loses density. And from the ideal gas law we know that if you lose denstiy you lose temprature. Therefore an intake that can flow air faster will have less dense air and and less dense air means colder air.
99' eclipse GS 420A !!!TURBO!!! Hahn kit installed. still on stock everything else, including exhaust.
I know it's taking FOREVER to finish the write up but the bands been taking off lately killing my free time. I've got some pictures posted though if you want to check it out.
www.angelfire.com/indie/kbracing
Old 11-13-2005, 07:39 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
wow. What a debate about science. Who cares if the thing spins, condenses or makes an F5 tornado in your intake. It's still a piece of crap worth maybe 1-2 hp if that. And that's the bottome line. heh.
1991 GSX 2.3 Stroker
Old 11-13-2005, 10:40 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Originally Posted by defiancy
Who cares if the thing makes an F5 tornado in your intake.
I would care.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-14-2005, 10:32 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Hey;
It's good to have debates like this. News and some schooling for everyone. Thanks guys!!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
