#16
Re: wiping the rain away
But there is one way to find out. MT
#17
Replace the pulse board and your troubles will be over, $30.00
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
#18
If you haven't changed the pulse board, then I'd say yes it is the pulse board. I had 2 problems with my wipers. One was the pulse board....It had a broken trace and bad solder joints on the connector. After fixing those things, it was fine. The second problem just recently happened, they were not turning on, but I could hear the motor trying, I gave the wipers a nudge and they are fine again.
1998 Blazer 4WD 4.3L 118,000miles 4dr Repairs--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion. --Bad ABS ground, loose connection blower motor, repaired pulse board. Mods/upgrades-Throttle plate mod. 1999 Ford Windstar SE 3.8L 160,000miles Repairs--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs. |
#19
Hey,
I had the same problem (98 GMC jimmy). All my research pointed to those soldered joints on the circuit board.. I pulled the board and didn't see any problem..until I looked at the joints under a magnifying glass. (they are the joints on the "back" side of the circuit board. The side without any components.) I found several hair line cracks in some of the joints. To fix them, I just touched a soldering iron to them and remelted them. This was about late Oct. or Nov. 2005 same as you. I haven't had a single problem since them. Next time they won't work. Pull over, pop the hood and jiggle the box the circuit board is in. I used to do that and they would sometimes kick in.. It helped me isolate the problem to the board. |
#20
All it took to fix mine was to pull the pulse board, wipe the collection of grease off the spring contacts, quick spray with cleaner, and voila!
#21
