Old 04-19-2008, 09:53 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Thor car alarm system
dang, I thought poncho had fallen off the planet ...
I guess you just skim thru nowadays.
Old 04-21-2008, 06:04 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Yeah, my bizz is popping now and don't have much time to whore around here like I use to.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 05-14-2008, 02:18 PM
dan323 dan323 is offline
i have a thor remote start car alarm i'm just wondering where you put the sensors i've got all the other wiring done. If some could help me that would be awesome. Thanx
Old 05-14-2008, 08:38 PM
Audio Guy
what sensors ?
Old 05-14-2008, 10:56 PM
Originally Posted by PaulD
what sensors ?
sorry paul figured out they were relays, but still havin a hard time to figure out what they actually all connect to, the diagram they show isn't that great. this is my first alarm/car starter i've tried installing. So if you could help that would be great. Thanx Paul.
Old 05-15-2008, 07:03 PM
Audio Guy
I can try .... can you scan the wiring diagram, or provide a link - maybe we can make heads or tails of it.
Old 07-30-2009, 03:08 AM
schaw schaw is offline
I have read alot about the problems thor is giving people and I wish I never bought the dang thing but I did and want to atleast try to use it..
I have read over the poorly translated manuel and the thing that is stumping me is the lock and unlock wires.
I have a 98 eagle talon. If anyone has installed one of these in this tpe of car please hit me up and help if you can with the 6 diff. freaken wires they have compaired to the 2 wire switch I have in the door.
Any help woud be greatly GREATLY helpful.
Old 07-30-2009, 06:01 PM
Audio Guy
it probably has two sets, one for cars that have pos lock and the other for cars with neg lock
Old 07-30-2009, 07:25 PM
Aye, I messed around with it today to try to figure it out.. Seems to work now.. had to jump the pos/neg org with the const. power and pos/neg yellow to the ground.
Got it all set up and installed.. Only prob now is the remote start. When armed or what not to start the car it turns the ACC on as its about to start but does nothing after that ACC goes off. Not sure if its the motor wire (sensor wire) that I have connected to my tack wire or not. Will disconnect that just to see if that could be it. If its not then Im back to the drawing board.
Right now I have the blue to the acc blue from the replay, the 3 relays the reds jumped to one to the const. power the black to the ON the white to the other ON asssuming its the AC ON as when I start the car that wires output dies till the car is started and the blue wire to the start wire that has no current when on ACC or ON but lights up when the key is turned to START.
If this makes any sense to anyone that could help that would be great....
Old 07-30-2009, 07:36 PM
Originally Posted by ponchonutty View Post
Once the tach is hooked up, you have to make the remote starter "learn" the signal. You don't have to use the actual tach either. A signal from an injector will work too. Just find the wire color that's not common with the other injectors.
I wonder if this is the prob then that it has to learn the signal.. how do you make the alarm learn the signal? I have not yet unhooked the tack wire to test just curious as I just re-read this?
Old 07-30-2009, 11:54 PM
Audio Guy
I have never done an auto start, so I really can't help you on this part
Old 08-02-2009, 04:08 AM
I got it all figured out.. what a pain... well if anyone in the future has any probs with this alarm for installation shoot me a private message and I will do my best to help ya out...
Old 12-06-2009, 12:57 AM
porschehi porschehi is offline
Originally Posted by murd3rd View Post
1998 ford taurus alarm, remote starter, keyless entry wiring informationconstant 12v+yellow or light green/purple ignition switch harness starterred/light blue ignition switch harness ignitionred/light green ignition switch harness ignition 2gray/yellow ignition switch harness (blower motor) ignition 3red/black ignition switch harness (ac) accessoryred/black ignition switch harness (heat ac) tachyellow/black multi coil (tan/yellow passenger's firewall pcm 48) neutral safety wirenot grounding oem switch opens starter circuit brake switchred/light green brake switch trunk releasegray/red (+) in left kick panel (+) trigger trunk pinblack/pink (-) trunk light (wagon white/purple right cargo) parking lightsbrown (+) light switch head lampred/black (+) harness left of ignition switch harness factory disarmpink/white (-) driver's kick panel (pink/blue to arm) door triggerblack/light blue black/blue in left kick panel. Door lockpink/yellow (-) driver's kick panel door unlockpink/green (-) horn wirepurple/orange
(-) steering column 4 pin connector windows uplf=white/black, rf=white/yellow, lr=yellow/blue, rr=yellow/black windows downlf=orange/white, rf=tan/blue, lr=gray/orange, rr=red/black
hi, i got a system for my car called a thor pro alarm and it came without the wiring diagram. All i am looking for is the diagram which is supposed to come with the un it when purchased. I tryed winging it and it is driving me crazy. Please help. Thanks, chris.
Old 12-06-2009, 09:33 AM
Audio Guy
I have never seen one in person. From looking on the internet, looks like they are overpriced and have lots of problems - including poor customer service. Have you tried going to their site and getting the info straight from them ?
Old 12-19-2009, 06:38 AM
Do yourself a favor and Ebay that Thor alarm
Pioneer 4900mp
Orion C63 Coax rear
