#16
Re: Re: Wicked!!!
Re: Re: Wicked!!!
Re: Re: Re: Wicked!!!
So what do you plan on doing? Finding a used KA or are you going to go the SR route? Let us know
Re: Re: Re: Re: Wicked!!!
I am going to buy a SR from Unstable-Hybrids (just wouldn't be a SilEighty without a SR20DET ). I'm getting the S13 Silvia Conversion form them as well, and a full Bomex body kit(not from Unstable). I'll Post other mods i plan on doing ie. Engine, suspension, ect. soon as I figure it all out.
#20
Re: Re: Re: Re: Re: Wicked!!!
Re: Re: Re: Re: Re: Re: Wicked!!!
Planed Mods
Here is a list of mods i plan on doing (overtime).
Engine -Unstable Hybrids Red Top S-13 SR20DET $2500(USD) -Trust Turbine Kit, Turbine TD-06S 20G-8.0cm2 Part# 11520004 TKIJ Part# 9463 $2980(USD) -Trust Intercooler Kit, Type24 (H280 L600 W76) 2 Layer, Side Tank In/Out No.26/No.26 TKIJ Part# 9575 $925(USD) -HKS Super SQV Blow-off Valve TKIJ Part# 4816 $231(USD) -HKS Stopper Type Head Gasket 1.2mm Compression Rate 8.3 Bore 87.5 TKIJ Part# 11072 $188(USD) -HKS Reinforced Valve Springs TKIJ Part# 10956 $156(USD) -HKS Camshaft 256 deg. Duration IN. 10.5mm Valve Lift TKIJ Part# 10909 $266(USD) -HKS Camshaft 256 deg. Duration EX. 10mm Valve Lift TKIJ Part# 10910 $266(USD) -HKS Adjustable Slide Cam-Pulley TKIJ Part# 18194 $117(USD) -HKS Adjustable Slide Cam-Pulley TKIJ Part# 18194 $117(USD) -HKS Super Power Flow Intake Kit TKIJ Part#986 $138(USD) -HKS 450cc injectors Part#1402-RN006 TKIJ Part#11308 $172(USD) -HKS Fuel Rail Part#1407-RN001 TKIJ Part#11299 $211(USD) -HKS Fuel Pump 60L/H Part#1407-RA002 TKIJ Part#11331 Electronics -AEM EMS Programable Engine Management System $1400(USD) -HKS Turbo Timer Type1 TKIJ Part# 17360 $116(USD) -HKS Turbo Timer Harness Type NT-1 TKIJ Part#9129 $9(USD) Transmission -Trust Power System 6 Speed Transmission TKIJ Part# 12461 $6101(USD) Clutch -Cucso Rocket Clutch Disk TKIJ Part# 2417 $243(USD) -Cusco Rocket Clutch Cover TKIJ Part# 2477 $250(USD) -Cusco Chrome Flywheel 4.8Kg TKIJ Part# 2370 $329(USD) Suspension -Tein FLEX Damper, Part# DSN20-61SS1, Spring Rate (Front Kgf/mm:5, Lbs/in:280) (Rear Kgf/mm:4, Lbs/in:224), MSRP $1560(USD) W/Pillowball Upper Mount -Tein EDFC (Electronic Damping Force Controller) Part# EDK01-12140 MSRP $380(USD) I haven't figured out what Brakes, Wheels, and Tires I want yet but I'll post when I do.
#23
long way to go man but tight
if you get all those parts you'll have a hell of a car![]() BTW for the brakes how about some Brembo kit?
Finaly got my RS13 now need money to mod it![]() Fun is not a straight line. AFs member #299, loyal european support since 02/2001 .
#24
wth
wth good is a chromed out Flywheel going to do you? no one sees that LMAO.... that'd be like getting the insides of your exaust pipes chromed LMAO......... you get flywheels for lightweight so your engine revs faster, don't get one dipped in heavy chromium...not a wise decision.
#25
Re: wth
Nice list of parts onevia. What site are you at that your copying and pasting all that stuff from. I'm just guessing that your doing that because of all the part numbers and all
why don't you buy one that isn't chromed from another company, Im sure it will be lighter, nothing like a heavy coat of chromium on parts you pay for the lightweight lol... just common sense
#28
Most of the stuff (TKIJ Part #'s) is from Taka Kaira Inc Japan (www.takakaira.com). The rest is from the manufacturers websites. |
#29
http://www.jspec.com/nismoflywheel.html theres the NISMO flywheel....
sure that would be better then a chrome one..... theres probably a few more but I heard someone on here say they heard of a few bad experiences with other aftermarket ones...... |
