Old 10-27-2005, 02:04 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: 8th order bandpass
http://www.the12volt.com/caraudio/boxes6.asp
Old 10-27-2005, 02:07 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Look at that picture, the two main enclosures are the same size and tuned to the same frequency, that's a normal 6th order just with a common chamber instead of separate chambers. That's not what you're doing.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-27-2005, 03:33 PM
Jet-Lee's Avatar
Banned
how does the tuning of the port effect the type of box? 3 chambers, all ported, 2 drivers = 6th order bandpass. The fact they share a chamber makes it a dual reflex. What does tuning have to do with the TYPE of box?
That's like saying because my car is N/A and my buddies is turbo'd, regardless of the fact they are both 1999 Escort LX's, the fact that his is turbo and mine isn't, then my car isn't an Escort, or his isn't, because they're not "tuned" the same.
Old 10-27-2005, 04:31 PM
sr20de4evr's Avatar
Because the two outer chambers are tuned to the same frequency, the two subs move identically. Because of this, the inner chamber can be assumed to have a wall in the middle separating it into a chamber for each sub, just like having a pair of identical 6th order bandpass boxes sitting side by side. Your box does not function that way, the alignment changes drastically depending on what frequency you're playing, I hope to god you found a program that can model this box for you, if not you're just shooting a bb gun into the sky hoping you hit a satellite.
If you take a 2cf 30hz box designed for 2 10's, you put a 10 in one hole and a PR in the other hole, it's no longer a 2cf 30hz box, it's just fucked up is what it is.
A 6th order bandpass is called a 6th order bandpass because you have a 4th order rolloff on the bottom end and a 2nd order rolloff on the top end. I highly doubt yours behaves this way, so it can't be classified as a 6th order bandpass IMO.
'01 Black Sentra SE
'05 Silver WRX STi
Old 10-27-2005, 05:27 PM
Jet-Lee's Avatar
Banned
I'm making one tonight, with 3 slot ports, will let you know tomorrow how it sounds.
Old 10-27-2005, 06:51 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
want to see how a dual chamber 6th order SHOULD be designed?
http://www.soundsolutionsaudio.com/f...showtopic=4316
Old 10-28-2005, 08:16 AM
Jet-Lee's Avatar
Banned
okay, the 10" version is built.
It is the exact opposite of what I thought, but it's unique none-the-less. It's a drop in volume from my previous design(horn loaded), but the quality is 10x better than any setup I have ever heard anywhere. dropoff does not occur till ~25hz. That's already below the limits of my subs (28hz) so I don't care. Pretty level on up to the crossover at 90hz. The accuracy is just astonishing! You can tell the smallest of tone changes, or tiniest thumps. I love it for the quality aspect, it still has some spl, but not what I had.
Old 10-28-2005, 01:30 PM
CBFryman's Avatar
Banned
that funny because proprly designed horns are not only the most efficent but also the most accurate and natural sounding alignments.
Old 10-28-2005, 02:04 PM
Jet-Lee's Avatar
Banned
My horn wasn't sized right in the least bit. I just took some wood and slapped it together to see what the big deal was.
Old 10-28-2005, 08:19 PM
CBFryman's Avatar
Banned
Then i can understand a great improvement
Old 10-28-2005, 08:30 PM
CBFryman's Avatar
Banned
a lil horns 101 (im no horn expert)
a true bass horn has a mouth size the size of the wavelength of the inteded frequincy, however due to horns small roll off frequincy smaller mouth area's can be used, especially if the sub is being designed for corner or wall placement in an enclosed area.
http://melhuish.org/audio/hornshape.html
