Old 07-28-2007, 11:38 AM
sierra99 sierra99 is offline
Re: Service 4wd indicator, 99 silverado
My 99 silverado lt has done the same thing....I read all of the post about the transfer actuator but I looked at the switch itself. Pull the switch and take it apart. Look closely at the solder joints in the back of the switch while pushing on any and all of the buttons. Mine had a hairline crack in the solder joint. I had the same symptoms. Now you can either replace the switch or get a soldering iron out and add/ resolder all of the joints. I resoldered all of my joints. Now all is working great. Try that..
To get the switch out do this:
1 put key in ignition turn to on position without starting the truck.
2 put truck in drive with the motor off
3 Making sure the truck has the parking brake set.
4 pull on the bezel surrounding the gauge cluster radio and ac controls.
5 tilt steering whell all the way down
6 remove the free bezel
7 unsnap the 4wd switch
Old 07-28-2007, 12:06 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Originally Posted by dan clark
how do you get the switch out ? how do you remove the dash
Welcome to AF.
This post is almost two years old.
Always check the date on a post before posting to it.
If it is old let old sleeping dogs sleep in peace.
If you need info on yours start a new thread and someone will help you.
MT
http://www.automotiveforums.com/vbul...45#post4820845
http://www.automotiveforums.com/vbul...wthread&f=2072
MT
Old 07-28-2007, 12:11 PM
I see that it is old but on 7-12-07 Dan Clark wanted to know how to remove the switch I was answering him. Just trying to help
Old 07-29-2007, 08:32 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
An oldy but a goody...
Old 07-29-2007, 08:49 AM
taillight taillight is offline
Don't you just love being scolded on line. Makes you feel like your back in 3rd grade.
