Old 10-24-2005, 12:30 PM
3SBlkStreak's Avatar
3SBlkStreak 3SBlkStreak is offline
Re: Top speed
I've had mine up to 130(and still had room left) and I'm bone stock. I have a 98' SL DOHC
Old 10-24-2005, 05:53 PM
mgk563 mgk563 is offline
Send a message via AIM to mgk563
I had my 94 sl goin 135 in 4th gear on a 2 mile stretch. I havent drove it in 2 months tho becasue it lost my licence for me. or my lead foot lost it for me
Old 10-24-2005, 06:39 PM
Law_3KGT Law_3KGT is offline
Re: Top speed
damn i had a long straight away and only got my stock 94 sl up to 125 and that was going down a hill. it doesn't seem like it will go past 120 without a hill though.
Old 10-24-2005, 06:46 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Top speed
You sure you may not be off a tooth on timing? That could very well cause the lack of top end.
Old 10-24-2005, 07:02 PM
Gateway's Avatar
Gateway Gateway is offline
Re: Top speed
I've had my car up to 157 with an extra 700 pounds on the car...only reason I slowed down is cuz I was coming to the end of the road
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 10-24-2005, 09:05 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Re: Top speed
^lol you have a lion, the other guys have coyotes... not a fair comparison!
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 10-25-2005, 07:09 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: Top speed
Anyone else here with a SOHC? I'd like to see what the highest possible speed on one of them is....
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-25-2005, 04:05 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Top speed
so the sl does 150mph? some say higher, and the vr4 only does 10-20mph faster with 100hp more?
aero
Old 10-25-2005, 04:48 PM
Re: Top speed
I had always thought the SLs maxed out around 140ish and the VR4s around 160ish, but it doesn't seem to look that way... I guess I was expecting a bigger number from the VR4s top speed... somthin more like 170ish?
Old 10-25-2005, 11:51 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Top speed
i've taken my 93 base for several top speed runs. i can only get it to 125. there just doesn't seem to be enough power to get it beyond that. mine's pretty much stock as far as the engine goes. not sure how the other later SL's can get up around 140ish.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-26-2005, 07:17 AM
Mikelb's Avatar
Re: Re: Top speed
Turbo engines are also less stable than NA engines at their top most speed, to push it too much higher, it wouldn't be able to handle the compression and or speed... I don't forsee a much higher top speed for the VR4, I just see it getting there faster... but it also depends on gear ratios... throw a taller 5/6 gear in there... and you'll be able to go faster, b/c your rpms will be lower and the engine will have a little more headroom
Old 10-26-2005, 02:57 PM
youngvr4's Avatar
STREET RACING GURU
Re: Top speed
the car weighs 3800lbs, its stable enough. 320hp vs 222hp should by far have a much higher top speed then a sl
in that case some claim to have run up to 172mph in there vr4. the gears are made for 205mph in the first gens and 225mph in the 6 gears.
its like saying the v6 mustangs top speed is close to that of the cobra.
but i'm not an expert on aero, yogs is, maybe he'll see this and give some input.
Old 10-26-2005, 03:24 PM
2old 2old is offline
Re: Top speed
I hate to tell you I told you so but I think we are coming back to my first point...
I have no doubts that people have seen 140-150 on their speedometers but that can be 20 MPH off at that speed...
I don't know if many people realised this but most speedometers read high because it's regulated to do that. The problem is no-one regulates just how much higher (the law suggests 0-20% higher then the actual speed but gives penaties if it reads lower then the actual speed).
Also what type of surface were these people on... 140 on cold asphalt is very different from 140 on hot asphalt.
I guess my point is... I wouldn't take all these Max speed numbers too seriously.
Old 10-27-2005, 03:28 PM
youngvr4's Avatar
STREET RACING GURU
Re: Top speed
me either
good point
Old 10-27-2005, 07:44 PM
Re: Top speed
2old man you do make a great point, I'd never thought about it that way
