Old 05-23-2002, 07:21 AM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
The PCV system reduces hydrocarbon emissions by scavenging crankcase vapors. It does this by circulating fresh air from the air cleaner through the crankcase, where it mixes with blown-by gases and is then rerouted through a PCV valve to the intake manifold.
To maintain idle quality, the PCV valve restricts the flow when the intake manifold vacuum is high. If abnormal operating conditions (such as piston ring problems) arise, the system is designed to allow excessive amounts of blow-by gases to flow back through the crankcase vent tube into the air cleaner to be consumed by normal combustion.
Maybe that will explain in for you.
R.I.P. - You shall be resurrected.
Old 05-23-2002, 08:46 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Originally posted by civic1991
Why connect something that relieves pressure form an oil covered area to the intake which inturn connects to the manifold???
Because the easiest option is to burn the gas.
It's a relief system, not something that should run all the time. IT usually kicks in more or worn motors.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 05-23-2002, 06:38 PM
darolh darolh is offline
Skynex is correct. In the old days the crankcase vent just dumped over the side (In fact my 4 year old tractor does). The Oil filler caps were often vented to the atmosphere too. With the addition of emission controls they are trying to minimize nasty vapors coming from other parts of the engine and not just exhaust. That's why the crankcase gases are vented into the intake to be combusted and so are the fuel tank vapors.
Pure race cars don't use these gadgets as there's no smog regs for them. They use puke tanks to catch oil (and other liquids) so it doesn't get dumped on the tires/track (when the rules say you must).
What Edelbrock Intake should i go with? inforcer958 General Discussion 4 02-14-2011 07:58 AM
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 03:48 PM
Oily residue on back window and lift gate benrlodge Escape | Maverick | Escape Hybrid 6 08-18-2010 01:03 PM
3.8 Intake Removal problem Jakal Park Avenue 2 05-23-2009 03:19 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 06:11 PM
