Old 05-27-2002, 07:15 PM
Dus10 Dus10 is offline
Ok I will still say the T-25 isnt worth the money. 6 psi isnt even worth it. whats that like low 15's in the 1/4. With a 14b a v-afc and a msd btm you can run arount 11 to 12 psi. Running 20 psi you just need a bottom end really. Spend some money about 2000 dollars get some good pistons and rods and upgrade a few things like your bov and of course use DSm 450CC injectors. Spend the extra money and get a 14b or eventually you will get it if you are serious about import drag racing.
Old 05-28-2002, 12:54 AM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
Low 15's???? I run low 15's with NO turbo and mild mods, I would guesstimate low 14's at 6psi with a good driver behind the wheel. You've got to remember that where 6psi won't do much to the 4G63 it will make a D16A6 scoot, especially in a light car.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 05-28-2002, 10:26 AM
I know what your saying when my civic was non turbo, no nitrous I was runnig low 15's with a D16. The reason why I still say low 15'S how many realy good" drivers do you know. Someone who goes from a 120 hp d16 civic to a 180 turbo civic isnt gonna be able to drive all that well at least for awhile. With a turbo its a whole new driving experience. I am in now way saying that the T-25 is a bad turbo it is just my opinion. A few of my frineds run the t-25. 2 of them have already gone to the 14b though cuz it had more potential.
Old 05-31-2002, 08:15 AM
Sikocivic's Avatar
Sikocivic Sikocivic is offline
Last year I ran mid 14s at 95 MPH on street tires, slipping clutch and no intercooler with 6lbs of boost on a T-25. I hope all you guys think think the T-25 is no good. Then I can buy them alot cheaper. This year I have a FMIC, boost controller cranked up to 10lbs and will be installing a stage 2 clutch soon. I will let you know how this " T-to small " runs this year.
Old 06-03-2002, 06:18 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Well, here is a quick update.
As for going with something small, that's what I want. I dont want to jump right in with the biggest, best, most expensive parts right now. I want to learn by starting small, and boosting low. Then as time goes by, and money is saved, I will work on a bigger turbo setup, and a bigger motor. See, us married people have other things to worry about than going fast. I also have my G20 that I am working on as well. So a backyard setup for my civic will work great for me.
Now, for the parts I have picked up. This weekend I picked up the header for a bank draining $9.00 and the turbo off a Mitsu. Conquest. My other options were the turbo's off the Saab's. The turbo's off the Lebaron's are put in a very bad location to try and pull in a junkyard. The turbo I pulled may be tricky to make an adapter plate for, since it only has three studs on the exhaust side. I may even end up ditching it for another turbo. But I will see on that. Right now I am searching for more info on this turbo, so if anyone knows of a any good sites on them, let me know.
edit: maybe I am looking at this wrong, here are pics of the same turbo I have. This should work right?
Old 06-03-2002, 06:42 AM
j3r3my-95 (G20)'s Avatar
j3r3my-95 (G20) j3r3my-95 (G20) is offline
how do you get a $9 turbo header?.... FREAK :bandit:
SR18? ... What the *@)#?!
Old 06-03-2002, 06:48 AM
kris's Avatar
It;s not a turbo header. Just off the base model 90' Civic. It looks like this:
Old 06-05-2002, 05:59 PM
Ok as far as us married people I am married and got kids..just to let ya know..
Old 06-06-2002, 05:32 AM
kris's Avatar
Yeah, but I have my wifes car to take care of, and my G20. The Civic is another toy to add on.
As for the turbo, does anyone know if it will work?
Old 06-07-2002, 04:17 PM
Sikocivic's Avatar
It should work fine. You will have to make a custom flange for the exhaust, or get the pipe that was on there and saw the flange off that. Then you can use it to make a custom downpipe. Good luck an have FUN
Old 06-07-2002, 10:28 PM
reXem reXem is offline
Hey...I have a turbo out of Mazda 626 (late 80s I think) just wondering what it compared to T-25? T3? I heard it was equivalent to a T3 but I am not sure....
How to choose the right turbo! APEXSER Engine 41 06-06-2012 04:50 PM
Picking out the right turbo for yout car sivic02 Forced Induction 0 01-07-2005 12:05 PM
how do you find the right turbo. raven_240 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 05-08-2004 02:17 AM
the right turbo for 2500cc h22 h22 N2O | Turbo | Superchargers 6 04-16-2004 03:33 PM
Is this the right harness for CEL diagnostic? Pics inside! Hybrid93Hatch Engineering/ Technical 1 04-17-2003 11:12 AM
