Go Back   Automotive Forums Car Chat > Racing > Non Specific
Old 10-04-2005, 10:33 AM
BullDog71ss's Avatar
BullDog71ss BullDog71ss is offline
Re: Re: SS/SC update: Face lift.
Originally Posted by eps
Should have saved for the pully. Doesn't look too bad I guess though.
I can have enough money for the pully upgrade within a month. The thing is that I JUST had a new motor put in and GM isn't too happy with me at the moment. The last thing I wanna do is put a pully/piggyback kit on this thing and then have something go wrong with my new engine install and have them bitch about my upgrade causing the failure. The car is also fast enough as it stands to get me in more than enough trouble for now. Pully's and other goodies will come later. I'm trying to get the real expensive stuff out of the way first anyhow, which means exhaust/intake comes next. When I say exhaust I mean header, manderal down pipe w/ high flow cat and 2.75 inch manderal pipes all the way back. I still havent found a muffler that I want to use yet. Anyone have experience with Vibrant's oval style mufflers? How do they sound and how do they perform?
The lug pattern is 115x5 w/ an 18x7.5 wheel. No one has anything that looks good.
Originally Posted by -Josh-
I like it
Thanks Josh.
Current vehicles:
2002 GMC Seirra 2500 HD 6.0
Mods-LQ9 engine, Custom 3" Magnaflow Exhaust, trailer brake controller, Hi-flow cats, Flowtech headers
2007 Mustang GT/CS
Mods-Vinyl stripes, int/ext aluminium trim, Billet shorty antenna, Hurst short shifter, BBK cai, Brenspeed 91 tune, Pypes o/r H-pipe, Billet hood pins
1971 Camaro SS 5.7 <-- Under construction
Old 10-04-2005, 11:27 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
you dont need a piggy back unit for a pulley upgrade. The cars computer will adjust the fuel and any needed timming.
And why is GM mad at you? They are the idiots who drove the car with no coolant and a broken radiator.
And honestly i really like the stock wheels GM put on them, u should keep them. Maybe just throw some Falken Azenis on them, but other than that they are nice.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 10-04-2005, 11:36 AM
Redcivic3's Avatar
Redcivic3 Redcivic3 is offline
Send a message via MSN to Redcivic3
When does your CAI come in ?
Old 10-04-2005, 11:44 AM
The piggyback removes the pcm's 14.5 pound boost limit on the SC bypass valve. In doing so you get around 16 lbs of boost. This is putting stock cars around 245 whp or so. I believe it also does a few other things besides removing the bypass valve limitation.
Check it out at www.revitupmotorsports.net
As for the wheels, I like them a lot as well. Problem is, everyone else has them to. I gotta be different . Plus the stockers arent feather wieghts either, it's like having lead wieghts attached to my car.
GM is pissed at me cause I gave them hell for a month straight about this car and I called them on all their BS they gave me. They were getting irritated with me by the end. I also found out from another SS owner the other night that his ABS system isnt functioning properly either, so I'll still be pursuing that issue as well.
Who the hell knows. I suppose when K&N gets off their asses and releases it. There have been all sorts of delays.
Edit: I take that back...I just looked on ss.net and it seems that kn just released the intake...woohoo.
Current vehicles:
2007 Mustang GT/CS
Old 10-04-2005, 12:22 PM
-Jayson-'s Avatar
i didnt know the PCM limited the boost to 14.5 lbs. Well u could just save up and spend a little more on tthe stage 1 and 2 upgrades. Atleast then you could keep your engine/power train warranty.
2009 Ninja 650 R
stock for now...
Old 10-04-2005, 01:02 PM
I might do that depending on how much GM is going to rape us on the cost for the upgrades. I wont bother with just the stage 1 though, as it is a wussy upgrade. I thinks it's an ecu reflash, injectors(maybe) and an intake. I could be wrong on one of those, but I think that's pretty close to what it will be.
Current vehicles:
2007 Mustang GT/CS
Old 10-04-2005, 01:12 PM
-Jayson-'s Avatar
heres all the info for ya
With 205 hp and 200 lb-ft of torque on tap from a lightweight aluminum overhead-cam 2.0-liter four-cylinder, the supercharged model is lively. But if you really want something to get charged up about, stand by for Stage 1 and Stage 2 upgrades for the SS Supercharged (and Saturn Ion Red Line) due in early 2006.
Stage 1 adds revised fuel injectors and new engine calibration to pick up another 20 hp; Stage 2 increases boost via a smaller supercharger pulley (along with another engine recalibration job) to amp up the torque by about 20 lb-ft. The packages can be readily installed by the owner. Pricing will be announced in November at the Specialty Equipment Market Association show in Las Vegas.
While the Stage 1 increases power, the added torque in the Stage 2 package is worth the extra cost and effort. The added boost provides a substantial increase in power, especially at the low- and mid-rpm range where base and Stage 1 models need a downshift to prevent running short of breath.
Need more incentive? GM Performance hoss John Heinricy says he expects a 20 percent power boost from the Stage 2 kit “when all is said and done.” That’s about 246 hp and 240 lb-ft, if you’re keeping score.
No prices as of yet.
2009 Ninja 650 R
stock for now...
Old 10-04-2005, 02:10 PM
I was one part heavy on the stage one is all, heh.
GM can still try and prove that these upgrades they offer caused damage to a vehicle is something goes wrong. So I'd rather just get the aftermarket stuff that's just as good for a better price. The piggyback system can also be upgraded later on down the road, which is nice.
Current vehicles:
2007 Mustang GT/CS
Old 10-07-2005, 12:54 PM
Igovert500's Avatar
blue + red light magnet
Oh, here is the thread I missed. Glad you got your car running again. Looks good.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
