Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 09-27-2005, 10:10 PM
GudeCiv's Avatar
GudeCiv GudeCiv is offline
Send a message via AIM to GudeCiv
Re: Re: Super'd Built B18 Questions
Originally Posted by superbluecivicsi
if your serious about running the jrsc and plan on swapping out the rods and pistons, throw back in the old gsrs.
if your serious about upgrading the internals other than oem for boost, dont look at the jrsc.
good cams to boost are some $50 gsrs.
I understand the gsr cams are more effective for boost. Like two of my b16 buddies with gsr cams in their turbo set-ups. I do not have the old ones since it was a built motor package deal. I am wondering if 6 psi and a good tune will work on the compression i am running. If i change internals for boost, it will be turbo.
- HONDA THE POWER OF DREAMS -
MY RETIRED MOTOR WILL ALWAYS BE REMEMBERED
SOHC non-Vtec 1.6L 170hp (flywheel)
redline: 8,100rpm ---->
-Gude Race D16Y7 Head
-JDM ZC Block
-Individual Throttle Bodies
Old 09-27-2005, 10:24 PM
GudeCiv's Avatar
Re: Re: Re: Super'd Built B18 Questions
I might as well tell you what I want first. A responsive autocross car that still has some aggressive high end when called for. this could mean,
My motor set up with roots-type charger,
or ITB's with light valves and hot cams.
Pros of a charger: instant torque and proportional power band
Cons:Boost and relatively high compression iffy
Pros of ITB's: used to driving them, love the response, high end smoothness and featherlight operation
Cons: Less max power, mid range torque mushy, cams and itb powerband may be too high for practical autocrossing
-JDM ZC Block
Old 09-28-2005, 01:05 AM
97integrals's Avatar
97integrals 97integrals is offline
Re: Re: Re: Re: Super'd Built B18 Questions
Well I don't want to start a supercharger vs. turbo thread but if you are looking for an awsome set-up for road course or autocross and forced induction look into the gt28rs. It is capable of a little over 350whp from the set-ups I've seen and it has a sick power band and instant throttle. I am thinking about putting one on my daily driver. Here are some examples : http://forums.evans-tuning.com/search.php?mode=results
Old 09-28-2005, 02:09 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
well considering that its cr is higher than a type r by .2 which isnt much you should be able to run it safe. i would be better or safer to run it alittle lower cr but it should hold. just have it tuned good and always run 93
Team Lonely Drivers
